B & M vs Transgo sihft kit
Old Dec 21, 2009 | 11:50 AM
9D4Z28's Avatar
Question B & M vs Transgo sihft kit
i was at summit yesterday and the tech guy told me that B&M kits shift harder than the transgo HD2. any thoughts? wanted a second oponion from people who have expierienced them ?
Old Dec 21, 2009 | 12:44 PM
LT1WS6's Avatar
B&M sux.. all it is , its a bunch of spacers that deletes the 1-2 acc. and 3-4 acc.. A transgo kit is much more decent, and shifts real firm.. I would go with trans gos
Old Dec 21, 2009 | 02:21 PM
355z28's Avatar
Yes, they do shift harder but are HARDER on the trans. Like stated above they just stop movement of the accumulators basically. The Transgo Shifts fast and firmer IMO.
I ran a B&M transpak and broke several sprags in the trans, Switched to a transgo and fixed that problem.
Old Dec 21, 2009 | 02:23 PM
StealthFormula's Avatar
When I first stalled my car a couple years back I did alot of research and the TransGo HD kit seemed to be much better. I ran the HD kit for a while and it ultimately was part of the reason that the trans went but with a converter it's almost mandatory since the shifts get loose with a large stall converter. BTW, the TransGo can be set up with three separate shift firmness settings. I wouldn't even recommend running the harshest if the car is a DD. My current trans is built and it utilizes a custom shift kit that about snaps my neck when it shifts into second.
Old Dec 21, 2009 | 02:34 PM
pyro719's Avatar
I wouldnt put a shift kit in a 4l60e. If you want firmer shifts just turn the force motor up. Or you can make it shift harder in the computer by tuning the line pressure and shift timing. I have a CPT trans in my car and it has no shift kit and shifts real hard.
Old Dec 21, 2009 | 04:00 PM
Elliott's94Z's Avatar
I had the HD2 and it was pretty nice. Had a custom shift kit made by my tranny guy when I did a full re-build and it is simply bad ***. Out of the two go with the Transgo.
Old Dec 21, 2009 | 04:56 PM
96capricemgr's Avatar
First stop calling Summit for tech advise.
Second Transgo is almost almost the exclusinve choice of all the reputable 4L60E builders. Not only is it a shift kit but corrects some factory flaws. Most shops building trannies for normal DD cars use Transo "fix it" kits just to correct the factory flaws that caused the failure.
Old Dec 21, 2009 | 06:33 PM
sleepys10's Avatar
trans go is what I would run
Old Dec 21, 2009 | 07:50 PM
irocurpony8489's Avatar
Default pro built automatics
id go with the pro built trans go shift kit http://700r4l60e.com/ nice part throttle shifts for around town and firm wot for the track.
Old Dec 24, 2009 | 06:45 PM
LT1WS6's Avatar
Originally Posted by pyro719
i wouldnt put a shift kit in a 4l60e. If you want firmer shifts just turn the force motor up. Or you can make it shift harder in the computer by tuning the line pressure and shift timing. I have a cpt trans in my car and it has no shift kit and shifts real hard.
but you are using only pressure for hard shifts... What a shift kit does is increase volume and pressure accordingly.. I think any tranny buikder would disagree with you
Old Dec 24, 2009 | 06:55 PM
kinglt-1's Avatar
Originally Posted by LT1WS6
but you are using only pressure for hard shifts... What a shift kit does is increase volume and pressure accordingly.. I think any tranny builder would disagree with you
I agree, op go with the trans go kit, thats the right way to make your tranny shift firmer imo...
Old Dec 25, 2009 | 11:46 AM
pillarpod's Avatar
I have the TransGo HD2 and i love it
