Keep picking up 1mph by removing air filter
-The first track outing the car went consistent 113.xmph with filter. With filter removed the car went consistent .x.
-The second outing the car went consistent 114.xmph with filter and 115.xmph removed.
DA between runs both days were negligable and the ET differences were minimal, just had changes in MPH. The changes were about a full mph between running a filter and no filter. I didn't think that a clean K&N air filter on a Ram Air setup was restricting a mild heads/cam 350 any? Hopefully there may be some less restrictive air filters out there that I could use for street use. Are any you heads/cam or stroker guys with Ram Air boxes running anything inparticular? I have been pondering testing out an LS1 lid setup especially since I recently took out my front bumper support and plates on the bumper which would really force in some air, not that a mild 350 needs a ton of air flow but maybe worth a shot.
It's a tradeoff, you don't want dirt, sand, rocks or small animals getting in there, do you?
I (and most of people I know who race) run filterless at the track then re-install for the trip home.
I have screens in my hood and intend to leave them there.
You aren't risking your motor running without an air filter at the drag strip. You are only running for short periods of time and for the most part the air is clean.
. Actually last time I was at the track, I tested it both ways and the car went 1mph faster with the filter.
I think it has more to do with the weather, temp and DA of how the car reacts to pulling it.
