v-band clamps, taking them off?
I got some v-bands welding on my headers, but I can't get them off?
I'm trying to take of the headers to do my head gaskets. Look like this.
I took off the screw, all the way off, now what? Header isn't budging after this step.
A screw driver under the shoulder of the clamp should set it free.
If that doesn't work, a flat screwdriver sat on either one of the open ends and tap with a mallet will flex them open and off.
Here is a trick to seating them back correctly for leak free tightness. While tightening the clamp, hit the clamp hard with a plastic mallet. Tap and turn, it will vibrate the ends of the pipes together and in place.
Good luck.
Good luck.
The 2 flat sides seat correctly against eachother and seal perfectly (as long as you tap it to make sure they aren't just stuck at and angle and are seated right).
