stock 95 pcm boost limitations
Old Dec 26, 2009 | 09:46 AM
sofixy89's Avatar
Default stock 95 pcm boost limitations
Hi i was trying to search around but i cant seem to find anything
What is stock pcm (95 camaro obd1) boost limitations?
What can you do to increase it?
Thanks
Old Dec 26, 2009 | 10:36 AM
96capricemgr's Avatar
If you dig in the pcm section you should find some info about running a 2-BAR MAP, it compromises resolution though because the pcm is really only meant to handle 1BAR. That is a recent thing though people made it work single bar for a LONG time. People have found workarounds for a LOT. By the time you get all the tuning figutred out at substantial cost you might actually consider aftermarket management setup for multiBAR MAP.
Old Dec 26, 2009 | 11:03 AM
lt170chevelle's Avatar
the problem with 1bar is you only have your 100kpa graph bar to tune your timing and afr . the prob with that is if you are running ..say .. 15 psi..as soon as you go wot it hits that 1 bar on the grapghs to reference and loads it with fuel and low timing before it even hits boost. Its just a slopy way to do it.Ive been running the two bar and it works great. This setup only uses 50kpa and under for n/a tuning(when not in boost) then 55kpa and higher for boost. so now you have a bar for like every 2-3 pounds of boost rather than being stuck with the one 100kpa section of the graph.Its alot better all around and all you need is a 2bar and lt1edit or tunercats for programming.
Old Dec 26, 2009 | 08:25 PM
4SFEDZ's Avatar
im running 14psi on my 94 pcm, and bout to go higher! a good tuner can do it no prob!
