Carb conversion parts : full list
Old Jan 4, 2010 | 03:25 PM
suicidal racing's Avatar
a carb engine makes more power then a fi engine..gm found this out in the 80s..a good read is right here..
http://www.pro-system.com/scoop92102.html
im also about to do a swap..going carb and not looking back..but i want to try and run a vic jr gen 1 intake on mine..so im going to have to mod.
Old Jan 4, 2010 | 04:36 PM
slownova73's Avatar
cool..thanks for that!
Old Jan 6, 2010 | 12:43 PM
no problem..what cam did you use to lay down them numbers?
Old Jan 6, 2010 | 03:23 PM
fleetmgr's Avatar
That's great if all you ever do is run around town at WOT. In the world of the daily driven car though, FI is a superior system. It will provide better mileage, better average power and longer engine life than a carb will.
Drag racers found that out decades ago that injected cars just didn't make as much WOT power using the old mechanical setups.
Old Jan 6, 2010 | 04:46 PM
slownova73's Avatar
if your talking to me then, idk wat the cams specs are, the original owner says its a custom grind, but when i pull it out for the build im a have it checked out and get the specs.
all i know about that cam is it idles nicely around 900rpm, and it starts pulling hard at almost exactly 3k an hauls *** up to 7k, and i turn it 7k on a eekly basis lol, im hard on my ****!
