Exhaust cutout make a difference on Cammed LT1??
thanks
Kris
I have no #'s to prove anything. Seat of the pants feel was more important then some dyno numbers
With duals right behind the collectors my old LE2 package would pull hard up top. I just have a single in the I pipe now due to clearance issues.
And all of those chiming in with that overused wornout wives tale of "losing torque because of reduced backpressure", go run the tests (intelligently....WITH DATA) for yourselves before regurgitating that crap.
All other factors being equal, reduced backpressure will ALWAYS result in more horsepower and torque.
The increased noise really plays tricks with people's "butt-o-meters" and brains, making them think that they're into the throttle more than they really are just because all that extra noise tells them it just has to be so!
There are other factors like collector length behind the headers that can enhance or reduce output, but again, all other things being equal, the less backpressure the better.
Even with a stock cam, depending on the flow quality of the catback, it's common to see 10 hp, reduced 60' times (that means more lowend torque for you nonbelievers
), and ET/mph improvement of 0.1 sec / 1 mph. Trending Topics
I gained nothing with mine on the dyno, but I do have a 4" catbacj & I kept it since it does sound wicked open
BTW, I'm about to buy an electric valve for my cutout. Does anyone know if summit's electric valve is any good?
