cc306 and trickflow heads
The 21degree Trickflow is UNTESTED so right there the HP guesses are baseless. That said IMO it will be under 400rwhp some heads/cam LT1s make 400+rwhp and the masses start thinking every heads/cam LT1 makes that, it is NOT the case though.
I am certain that ported and with the right cam those heads could go over 400rwhp BUT in as cast form with a too big dinosaur cam I don't see it happening.
The guys bashing ported stock casting just used the wrong shop, they can't seperate a bad decision from bad parts, can't admit their mistake was choosing the wrong shop instead of the wrong casting. Easier to blame the casting because the old one "did not work" so now they can claim when they buy aftermarket they are "fixxing" the problem.
There are enough of us going fast on stock castings to prove that in the right hands they are great.
10128374 Starting in 92 is one of the 2 "sweet" castings for porting.
10207643 found from 94-96 is the other "sweet" casting.
10205245 from 1993, and 12551561 from 1996 are not especially desirable, but can still be worked to some degree if you want to have them done.
