what heads ?
Old Dec 28, 2009 | 03:56 PM
93v8clone's Avatar
Default what heads ?
i have the opportunity to pick up a new set of afr 195,s ,but im also lookin at a set of le3,s that bein said i can get the afr,s for 1600 bills assembled what head do i run with i have the money just want oppinions
Old Dec 28, 2009 | 04:05 PM
BruceBufferTA's Avatar
Well the LE3 heads are probably overkill for what you need. Go for the AFR 195's.
Old Dec 28, 2009 | 04:17 PM
93v8clone's Avatar
really cause loyd says differant ,its a diff cam goin in
Old Dec 28, 2009 | 04:37 PM
slomarao's Avatar
is there any porting on the AFR's or are they out of the box?
If they are out of the box they probably flow pretty close to what the le3's do. Than it would boil down to the nitty gritty. CC's, hardware, matching cam, etc.
When i build my motor (if funds ever allow) I am going to get le3's, but thats just me.
Old Dec 28, 2009 | 04:46 PM
93v8clone's Avatar
the afr,s are out of the box cnc ports . im really thinkin le3,s but will that leave me dead in the water if i wanted bigger or will i be better off on the afr,s and have them hogged later if need be
Old Dec 28, 2009 | 05:15 PM
Z-RATED94's Avatar
Wouldn't it be cheaper just to send Lloyd some stock castings? If the AFRs are cnc'd does it leave any room for further porting? If so, why not just purchase the right size head to begin with?
StealthFormula's Avatar
What cam will you be running? Comrpession? RPM range? Street car or race car?
Running a 208cc head on a 358 would not be beneficial in my opinion over the 195 AFR unless you plan on turning some serious RPM. I would rather have much more low-mid range torque with the AFR 195's than a couple more ponies up top with a large head like the LE3's but again that is my opinion. It really depends on cam choice, if your spinning say 6500rpm, I would imagine a smaller head like the LE2 being beneficial over the LE3 because of more average hp/tq throughout where the LE3 may make more power but only beyond say 6000rpm. Just my .02.
A good read:
http://www.gofastnews.com/board/tech...t-volumes.html
Old Dec 28, 2009 | 06:21 PM
93v8clone's Avatar
so according that read ,id be better off with the le2,s or the afr,s over the le3,s .id be runnin the 306 cam or the le2 cam as a pachage if i go the le2 way or a gm847 if i go the le3 or afr route .my comp ratio is high at like 12.5 -1 im also spinnin it to about 6500 now on the bottle
Old Dec 28, 2009 | 08:12 PM
VF1000R's Avatar
Way too many options and not a clear enough direction. You need to detail what you are trying to do.
