rearend plug?
Old Dec 29, 2009 | 05:34 PM
snk-huntr's Avatar
Default rearend plug?
how inportant is the electrical plug that plugs into the rearend,I swapped rears and the new rear does not have the same connector,its a 95 ta..thanks.
Old Dec 29, 2009 | 06:05 PM
05HD's Avatar
Only important if you want the ABS brakes to work.
Old Dec 29, 2009 | 08:31 PM
snk-huntr's Avatar
I thought it had to do with the speedo being off a bit??
Old Dec 29, 2009 | 08:46 PM
shbox's Avatar
It has nothing to do with the speedo. If you changed gear ratios, then that would be the cause. Did you do any research before the rear swap?
Old Dec 29, 2009 | 09:14 PM
spaz1's Avatar
It's for the abs... if your speedo is off then the new diff has different gears in it than the one you took out. Easy fix with hp tuners.
Old Dec 29, 2009 | 09:27 PM
snk-huntr's Avatar
Just ignore that last post from me, it's been a long day!!
My old plug had 4 hole, all with the prongs in it and the new rear had the 4 holes, but only 2 prongs??
