pushrod length help
Old Dec 28, 2009 | 01:02 AM
31camaro's Avatar
Default pushrod length help
is anybody running .030 milled gm lt1 castings with gmpp impy ss headgaskets or the same thickness headgaskets? if you are can i please have your pushrod length?
Old Dec 28, 2009 | 08:35 AM
James Montigny's Avatar
Measure twice, order once.
Odds are you'll end up with 7.150" with stock lifters.
http://www.carcraft.com/techarticles...th/index1.html
http://www.circletrack.com/techartic...gth/index.html
Old Dec 28, 2009 | 11:05 AM
RamAir95TA's Avatar
What James said. Measure yourself. It's just not worth the risk.
You only asked for head gasket thickeness and how much the heads have been milled. What about deck height, cam choice, cylinder head choice (aftermarket?) and lifter choice?
That's why you need to measure yourself.
Old Dec 28, 2009 | 11:25 AM
31camaro's Avatar
true, the deck height on the block is stock, LE spec'ed bullet racing cam, stock gm castings, stock LT1 lifters
Old Dec 28, 2009 | 11:31 AM
RamAir95TA's Avatar
If your heads weren't milled then you could say stock length would suffice, but you're likely to need a shorter PR.
Old Dec 28, 2009 | 11:42 AM
31camaro's Avatar
thanks for looking, would would i be giving up if i got the 7.150 length pushrods now without messuring?
Old Dec 28, 2009 | 11:50 AM
RamAir95TA's Avatar
If the pushrod is too short, you won't get full travel of the valve, increased valve guide wear, increased overall friction, reduced power, and accelerated failure of the valve/guide/rocker/spring/etc.
Old Dec 28, 2009 | 11:52 AM
31camaro's Avatar
seems like to much to lose, lol, im stuck to measuring, thanks again man
Old Dec 28, 2009 | 02:55 PM
mdacton's Avatar
if there are not right it will destroy your guides and wear oput alot of parts fast......also will not perform like it should.
Old Dec 28, 2009 | 04:42 PM
31camaro's Avatar
thanks for the help, i talked to my machine guy and he said he would do it on friday or whatev sometime towards the end of the week
Old Dec 28, 2009 | 09:17 PM
1 Craz28's Avatar
If I were you I would use stock pushrods. That way they will bend before any damage is done to your poor car from you working on it!
Old Dec 28, 2009 | 09:48 PM
bigdan1's Avatar
buy a comp cam adjustable pushrod ,7702-1 visually check the rocker travel on your valve stem .....
I have 7.00 in mine ...stock heads, roller rockers
Old Dec 28, 2009 | 09:51 PM
31camaro's Avatar
good one jackass, i can believe you had the nuts left from being bashed on other sites to wanna even use a computer again, this link goes to this guys thread thinking he is gonna have a 400whp xfi292 cam shifting @5700... http://www.ls1lt1.com/forum/showthread.php?t=31747, get a life and have start reading up on your molten sodium fuel, i hear there thinking about marketing it
Old Dec 28, 2009 | 09:53 PM
31camaro's Avatar
thanks for the tip man
Old Dec 28, 2009 | 09:59 PM
1 Craz28's Avatar
I don't think I'm at 400hp probably a solid 330. I would like to mill the heads but I'm scared of P to V contact. I don't know. I do know it has got some ***** now!
Why the hell are you keeping your stock lifters? Dude go NSA! I hope you are'nt using your stock springs?
Old Dec 28, 2009 | 10:17 PM
31camaro's Avatar
the stock lifters were fine, ive got enough spring to compliment 2 of your cams, im running crane duals, 10 degree locks and retainers, manely ss 2.02/1.60 valves on some nicely p&p'ed heads, and a nice bumpstick from LE
Old Dec 28, 2009 | 10:37 PM
1 Craz28's Avatar
Nice, you might be back up to stock horsepower now?
If I changed to bigger valves I would have gone with LT4 sodium filled or titainium, solid ss is too heavy!
Old Dec 28, 2009 | 10:42 PM
31camaro's Avatar
LE said it should be around 400whp
Old Dec 28, 2009 | 10:51 PM
1 Craz28's Avatar
What makes him think you'll be anywhere near the LT4's 330whp when its all done?
Old Dec 28, 2009 | 10:56 PM
31camaro's Avatar
?? cause they heads flow better than stock LT4's, and my cam is way more aggresive than even the hot cam that lt4 didnt come stock with
