aftermarket pcm ??
i was doin alot of research last night and kinda dreaming but i was dreaming plans for the farther future. and i had a question. at wat point is the stock pcm no good? wat aftermarket computer is best for the ltx motor? and last question is it possible to put an actual distributor into the car with the motor still in? i think ive hear the block needs machining. id appreciate answers even though i was dreaming i was kinda planning.
Hey how much did the EFI connection run you? did you get the whole kit to make it run on a ls1 computer? I want this because I want to build my LT1 and not swap over but dont want to deal with replacing opti's AT ALL
With this unit the opti is 100% DELETED!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I got the kit for $525 which still needs the LS1 ECM coils and wiring harness to run. Since I am utilizing a double roller I am going to buy the TPIS billet timing cover as well. I'm on the fence right now with respect to which direction I am going with the wiring harness. I can either get the do it yourself kit for $100 or buy the plug and play for $850. I have heard the plug and play is very nice. I have little patience for things like wiring! lol
Its a beautiful thing.
I figure ya might as well spend the extra few hundred and save a ton of time and headache searching for a good condition harness and repinning it yourself, and just get a nice new one that will all plug right up.
I received all of my stuff from EFI Connection yesterday, 24x reluctor for the dr timing set, billet timing cover to work with th dr timing set, modded cam ps housing, custom wiring harness and 01 LSx pcm. Excellent qualit and workmanship, I can't wait to get everything installed in the car.
after talkin wit 355 i think im goin to call eficonnections monday and do this instead of the ltcc anyone know the difference in the plug and play harness and the stand alone?
They offer three, one for the vortec small block chevrolet and two for the LT-1. Very awesome looking CNC'd piece. It allows more room for a double roller timing chain. One of the LT-1 covers comes with a provision for the water pump drive and the other is with out. They are on efi connections web site.
I got the plug and play harness with the altenator power wire extended and a shift light connection, which will replace the entire engine harness. The "stand alone harness is more for if you're installing an LTx in a non 93-02 fbody.
