watcha think of this idea?
Old Jan 1, 2010 | 07:49 PM
slownova73's Avatar
Question watcha think of this idea?
i have a set of 1.52 and 1.6 pro magnums.. my cam going in is the XFI 292, i have beehives and shims also.
i was thinking to maybe control the cam a lil better use 1.52's on the intake lift side, and 1.6's on the exhaust side.
and maybe step up the exjaust valve from 1.60 to a 1.625, of something similar?
Old Jan 1, 2010 | 08:10 PM
Wicked94Z's Avatar
Install the 918s at 1.74 and you'll be fine with 1.6s
Old Jan 1, 2010 | 08:19 PM
slownova73's Avatar
thats the initial plan but this was just a thought, maybe give my springs a lil longer life ya no.
Old Jan 1, 2010 | 10:48 PM
1nicez28's Avatar
What springs are you running?
Old Jan 1, 2010 | 11:02 PM
slownova73's Avatar
new 918 beehives, and i got a pack of assorted shims
Old Jan 1, 2010 | 11:07 PM
1nicez28's Avatar
I would do whats just posted above and run the 1.6rr's
Old Jan 1, 2010 | 11:13 PM
slownova73's Avatar
i probbably will, or i may just try both and see what the differences are?
Old Jan 1, 2010 | 11:20 PM
1nicez28's Avatar
^is it gonna be worth the hassle to tear it apart twice or maybe a 3rd time? Idk if your doing it yourself but I'd just go 1.6rr's and call it a day.
Old Jan 1, 2010 | 11:22 PM
slownova73's Avatar
yea im doin it myself, but i like to experiment.
Old Jan 2, 2010 | 01:18 AM
duh's Avatar
duh
What do you have for heads??? Usually the staggered rockers are used to make up for a slacking exhaust port flow. Since the stock LTx heads (and therefore ported ones) don't have horrible exhaust port flow, you probably won't see a gain. But if you're like me, I'd do a dyno run with the 1.52's, the staggered set, then a full set of 1.6's. Figure three dyno pulls and what maybe an hours worth of work. I think it'd be great to see hard numbers out of it
Old Jan 2, 2010 | 11:54 AM
slownova73's Avatar
im runnin trick flow 195's, ive heard so much **** about this cam being a *** kicker on valvetrain parts so i had this idea.... but, im gonna run it anyway!
Old Jan 2, 2010 | 10:29 PM
SPEED#1's Avatar
just use those springs with the 1.6s and call it the day
Old Jan 3, 2010 | 06:25 AM
Wicked94Z's Avatar
Guy's are throwing the 918 beehives in at 1.80 and expecting them to handle those aggresive XFI lobes... I'm running 1518s at 1.74 with solid roller lobes and 1.6s... no float here. No reason to run the 1.5 rockers, the 918s with have enough pressure over the nose to control the valvetrain with the 1.6s. I wouldn't really expect the 918s to have a super long live with those lobes regardless of the rocker ratio. the 1518s would be good for probably double the life.
Old Jan 3, 2010 | 02:42 PM
slownova73's Avatar
your talking about the PAC 1518's correct?
