Lt1 Fuel Rails
Old Jan 5, 2010 | 09:54 PM
Lt1Porsche's Avatar
Default Lt1 Fuel Rails
What is the most amount of power y'all have run on the factory fuel rail design without any lean problems? Im building a head and cam 355 lt1 using a cc306 cam. Thinking of getting a set of 36's and a regulator and call it a day. Ive sorta started on a custom fuel rail setup but realized that its starting to cost more than i particularly want to spend right now. If i have to do it later on down the road i will but would like to start simple. All of this is going in a 87' 944 turbo.
Old Jan 5, 2010 | 10:15 PM
duh's Avatar
duh
With the setup your planning, stock rails will more than suffice.
Old Jan 5, 2010 | 10:16 PM
RamAir95TA's Avatar
For that amount of power you are well within the capacity of the OEM fuel system. I wouldn't start looking for more fuel until you're running substantial boost, nitrous, or seriously high overall power levels.
Ditch the aftermarket fuel regulator - it will only cause you problems. The stock regulator is plenty.
Old Jan 5, 2010 | 10:25 PM
96capricemgr's Avatar
Rail is not going to be a concern till you multiply that power at least 2 times, probably 3. I would replumb it(feed and return lines) to hit those levels but at your level even the stock feeds are fine.
Old Jan 5, 2010 | 10:29 PM
Lt1Porsche's Avatar
Awesome makes my life a lot easier and the build cheaper. Thanks.
Old Jan 5, 2010 | 11:09 PM
4SFEDZ's Avatar
stock rails are fine! im at almost 700 thru a th400 with stock lines and rails
Old Jan 5, 2010 | 11:20 PM
355TurboLT1's Avatar
Stock rails (with fittings added and backed by a full fledged fuel system) have easily gone way over 1000rwhp. No worries. And like alot of people here will confirm the stock lines can support quite a bit more than one would think.
Old Jan 5, 2010 | 11:54 PM
robsquikz28's Avatar
fuel rails will be just fine.
