ok, the power steering/alt relocation bracket list thread!
Old Jan 13, 2010 | 04:49 PM
suicidal racing's Avatar
yes there will be..me im getting the bracket that posted on here from jegs and will mod it.i dont see why people ar paying 100$ for the same bracket pretty much just with diffrent bolt and spacer lenghts from what i can see..ill make a thread about doing it in march seeing im not ditching my power steering and going to skinneys till the snow is gone up here
Old Jan 13, 2010 | 05:26 PM
bigbusa1's Avatar
that would be cool. i was comparing pics of the madman kit to the jegs kit i think it can be made to work
Old Jan 13, 2010 | 06:25 PM
me to..ive looked at mad mans and jakesz28 that he makes and they just look like a flipped jegs i posted with different bolt lenghts and spacers marked up 100$..there not makeing there belts so you know its a autozone belt an such..easy way to make spacers is copper tubing cut to length and washers on each side.
Old Feb 22, 2010 | 11:14 PM
slownova73's Avatar
ok, here is what i am goin to do with my setup, its cheap, and it will work!
use the stock bracket and cut it down for the alt only. this keeps the tensioner in place to do its job.
and my machinist friend made a PS pump bracket, and i used a PS pump off a buick, cheap! but effective! route the belt through and bam!
after alot of measuring and thinking, theres no way out of using a different PS pump, or keeping it on the pass side, unless using the expensive stuff.
Old Feb 23, 2010 | 03:46 AM
draggin97s10's Avatar
hey nova im in the middle of putting my vic jr on. what balance did you use so u could set timing? also did you have to take anything off your vic to make it sit down in betweeb the heads perfect? also what timing mark indicator did you use? sorry to hijack
Old Feb 23, 2010 | 10:49 AM
slownova73's Avatar
i used a proffessional products balancer, a gm opti block off plate, and my machinist used stock heads for a mock up, and he did take some meat off the side of the intake. but with aftermarket heads it wouldve fit fine. heres the area he milled down
Old Feb 24, 2010 | 04:39 PM
Thank you thats exactly what i needed to know. i figured some would have to come off there
Old Feb 24, 2010 | 04:40 PM
i also like how the water neck is milled off!!! whats the pn on the balancer and what about a timing marker?
Old Mar 22, 2010 | 05:09 PM
collier341's Avatar
Badass info man!! This cleared up a lot for me as I could never see myself breaking down and buying speedinc's kit for $500. (not knocking the kit at all just saying). Does this summit bracket look like it would also work??
http://www.summitracing.com/parts/SUM-340110/?rtype=10
Thanks!!
Old Mar 22, 2010 | 05:54 PM
slownova73's Avatar
Thanks!!
yea thats the same thing as the zoops bracket
Old Mar 22, 2010 | 05:57 PM
collier341's Avatar
happen to have anymore pics of this settup??
Old Mar 22, 2010 | 06:12 PM
  #32
slownova73's Avatar
mmmm no i dont bud, i cant do my setup yet, im broke as a joke, had to postpone plans.
Old Mar 22, 2010 | 06:29 PM
  #33
collier341's Avatar
yaaa I feel your pain there. Thanks anyways man!
Old Sep 12, 2010 | 04:43 PM
  #34
SonicZRO's Avatar
any update on this?
Old Sep 12, 2010 | 08:59 PM
  #35
slownova73's Avatar
Originally Posted by SonicZRO
any update on this?
kinda, i got my hands on an s10 PS pump, i made a bracket to mount it on low driver side.
and as for alternator, idk about thta one yet, ill probably just get a cs130 alternator, and the alan grove low mount pass side bracket, and be done with it!
I have most of the parts, just havent installed it yet, no need too yet really
