LS truck fuel pump
Old Jan 7, 2010 | 09:25 AM
Barney Z's Avatar
Default LS truck fuel pump
Hey, guys, I know this isnt the right section, but Im not a member on the truck site. Figured some of you may know some things about these trucks. Just helping a friend. My buddy has an 02 Silverado, and a couple months ago somebody (that didnt need to be fooling with wiring) put a CD player in his truck and it messed with all of his gauges. Well, he keeps driving it and a couple weeks ago it shut off with him one day. He thought it was the fuel pump(thought he run it out of gas and maybe the pump burnt up?) and replaced it and still nothing. Come to find out he has no power to the pump. Says he checked all relays and what not and all looks good. . . Any ideas? Did the screwed up cd install job cause an ignition problem finally? The ruck will turn over but not crank, and says no lights or codes. He did check that. Thanks in advance. . . .
Old Jan 7, 2010 | 09:42 AM
the_merv's Avatar
Veteran: Air Force
Check the ECM B Fuse..or ECM 2 Fuse..something like that. I have a 1999 Sierra and the FP went out, it killed that Fuse. It would crank over but no FP when it went out. Once I replaced that and the Fuse it was good.
Old Jan 7, 2010 | 09:50 AM
Barney Z's Avatar
Precciate it. He said he checked, but not sure if he checked everything. Going to try to go look at it myself this weekend.
Old Jan 7, 2010 | 06:34 PM
rkinney's Avatar
They had some problems with the wiring on the fuel modules in the trucks and Suv's. Some would blow the ECM B fuse. Usually if the fuse was blown, the wiring in the module would be burned. The new fuel pump modules come with a new style harness connector.
Old Jan 7, 2010 | 09:43 PM
transam5.7lt1's Avatar
Tell him to check the ignition switch, I mean the switch not the ignition cylinder. Its a harness that runs down the steering column, if its bad power is lost there.
Old Jan 7, 2010 | 09:45 PM
By the way, you can access the performance trucks website and use your same id and password from ls1tech.com there.
Old Jan 7, 2010 | 10:47 PM
the_merv's Avatar
Veteran: Air Force
Yup..my wiring was burned up. I got the Delphi replacement one from O'Rielly's and it came with new wiring that was a direct swap in.
Old Jan 8, 2010 | 10:07 AM
Barney Z's Avatar
Thanks for all the info guys. Gotta find out if he replaced that harness. If so, then guess the ignition. . . Thanks again!
Old Jan 8, 2010 | 10:08 AM
Barney Z's Avatar
Kinda got me wondering if that boy that installed the cd player may have tampered with that???
Old Jan 8, 2010 | 09:25 PM
I am pretty sure they messed with it trying to find power for the cd player, since most players need a constant power and a switched power from the ignition.
Old Jan 8, 2010 | 10:56 PM
the_merv's Avatar
Veteran: Air Force
Got to love people that think they know what they are doing..
Old Jan 9, 2010 | 12:22 PM
Barney Z's Avatar
Whats makes it so bad is the guy is supposedly an "electrician". . .
Old Jan 9, 2010 | 02:33 PM
the_merv's Avatar
Veteran: Air Force
Lol..I've met many "supposively's.."
Old Jan 14, 2010 | 10:27 AM
Barney Z's Avatar
Turns out it was a fuse the whole time. . . He checked the relay under the hood, but not the fuse in the dash. Thanks again for the info, guys.
Old Jan 14, 2010 | 11:44 AM
the_merv's Avatar
Veteran: Air Force
No prob..glad it worked out for you & your friend..tell him to not let dumbasses mess with his stuff.
Old Jan 14, 2010 | 11:58 AM
Barney Z's Avatar
Well. . . . his gauges still dont work, and Im sure thats got to do with the cd, but. . . . altleast his pump runs and he can get to work. The rest is between him and the electrician
