AIR pump delete Question
Old Jan 9, 2010 | 01:54 PM
1bad72's Avatar
Default AIR pump delete Question
I hate to beat a dead horse but, I removed my Air pump and installed Pacesetter mid tubes and was wondering where to get a plug to block the air fittings? I also remember reading that yo had to plug the vacume port but do you have to do anything with the electrical? I tried to go to Home Depot and Meclendons hardware stores with no luck.
Old Jan 9, 2010 | 01:57 PM
RamAir95TA's Avatar
Depending on what year your car is (you don't mention), 93-95s use a M22 oil drain plug, 96-97s use an M22. Most, hardware stores (at least around me) do not carry them and you'll need to go to a parts store.
I just tied the wiring harness out of the way. Use a 5/8" vacuum cap to cap off the fitting on the intake ducting.
Old Jan 9, 2010 | 02:06 PM
1bad72's Avatar
Awsome! The car is a 95. Thanks for the info.
Old Jan 9, 2010 | 02:19 PM
suicidal racing's Avatar
im glad you asked..i orderd my pace setter headers yesterday and there the race version..i new i had to make the egr block of plate for the intake..at the same time i install the headers ill be also putting a a/c delete pulley setup an ditching my a/c stuff but keeping my heat till the end of winter..but my a.i.r is going and egr..going to do weight reduction also..
Old Jan 9, 2010 | 05:09 PM
for thoughs who are doing this to there cars..the m22 oil pan bolt is a 1/2 with 20 threads.. You can save your self 2$ an go to lowes an get a bolt..i grabed a cast iron plug deal for it..it was 98 cents and then i just grabed a tapperd rubber cork that goes up in size to 5/8s for 79 cents..hope this helps some
