which oil pump?
Old Jan 10, 2010 | 11:10 AM
ElkySS's Avatar
Default which oil pump?
since i have to replace my oil pan, i figure i might as well replace my oil pump while im there.
which one should i go with? i was thinking one from the dealer and then put in a high pressure spring but i thing that will proove costly. any suggestions?
Old Jan 10, 2010 | 11:32 AM
01fxst's Avatar
I like my high pressure Melling I picked up from summitt. Came with a new drive shaft with metal collar. Are you putting a stock pan back on? Or are you putting a road race or drag race pan on? If you get a larger volume pan you could use a high volume pump.
And I agree, as long as the pan is off replace the oil pump, pickup, and drive shaft with the crappy plastic collar. I think the collar on mine broke and that is why my pressure dropped and killed my motor.
Old Jan 10, 2010 | 11:50 AM
Puck's Avatar
Melling 10554. Stronger select casting but still std pressure/vol.
You can use the GM white spring if you want more pressure.
Old Jan 10, 2010 | 12:54 PM
RamAir95TA's Avatar
Because the stock wet sump pump is submerged in oil all the time, it never really wears. I wouldn't bother replacing it as I've never seen a stock pump fail, IMO.
Upgrading to the GM white spring, tack-welding the pickup, and upgrading the pump driveshaft wouldn't be a bad idea though.
Old Jan 10, 2010 | 01:57 PM
ElkySS's Avatar
iv never seen a stock pump fail either but mne has been acting kinda funny. i keep loosing oil pressure in the higher rpms. so im gonna upgrade it a little just for insurance.
yea im gonna be running a stock pan. i do want more pressure tho.
where can i pick up that melling?
edit: nvm i just found it. that thing is kinda expensive tho. jegs has it for 85. the GMPP is 76
Old Jan 10, 2010 | 01:58 PM
RamAir95TA's Avatar
Any parts store has it. Jegs, Summit, etc.
Old Jan 10, 2010 | 03:48 PM
ElkySS's Avatar
well i guess if it comes with the driveshaft and collar its not a bad price
