for all those running beehives and the pac 1218's
I found this post to be the most informative on what you need to run a 918 style spring with LT valves/heads.
https://ls1tech.com/forums/10711840-post22.html
Good luck,
Larry
Good luck,
Larry
If your going with over a 600 lift cam don't run these springs.. They are good springs fir smaller cams and behave very well and quiet down valvetrain .. If duals is a option get patriots/Manley/pacs/cranes
Lots of us run .600 lift or a little more on beehives, lobes and springs just have to be spec'd by someone competent.
One self proclaimed cam guru was specing .600 max lift springs with the nastiest lobes he could find and going past .600 and his followers are feeble minded enough to believe it was a spring problem.
Mike
