crank pulley damper thing?! WTF *confused*
Ok so my TA the crankshaft pulley is doing the twist back and forth to were it looks like it's going to slipe off and slap me across the jaw. i took the belt off to make double sure and it's the outer ring that i can litterly slide with my hand easily. i'm trying to upgrade that over my 72 coming up this weekend but i dont know what its called to order it. i thought it was a crankshaft pulley and i searched it on here and people are saying that you still have to slip the damper or some **** like that. blah i just need to fix it and hopefully upgrade it at the same time. any help. i'm new to lt1's but i know turbo ls1's
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
the balancer has a rubber ring bonded between two pieces of metal. the rubber goes bad and the outer will spin. replace the balancer.if the motor isnt modified just get a stock replacement
