355 build almost complete!
Old Jan 13, 2010 | 06:01 PM
MattSapp95_T/A's Avatar
Default 355 build almost complete!
Well about a month ago I lost all oil pressure while doing a 2nd gear burnout getting ready for a nitrous pass. Turns out I sheared half the teeth off my oil pump drive. I pulled the motor out and replaced all the bearings and oil pump and decided while it was all out that I wanted to go auto so I traded my M6 setup for a built th350...
also I
- relocated the fuel lines
- relocated the battery
- Installed an MSD box so I can adjust timing (I was running with -4 timing for my nitrous tune)
- Pulled the A/C out (Never used it and the car only get driven maybe twice a month) and made a block off plate
Here are some pics of the motor before it goes back in
Motor specs are in my sig
Old Jan 13, 2010 | 06:12 PM
Z-RATED94's Avatar
Sweet looking ride you have there. Should be much quicker too with the auto. What converter and stall rating will you be running? Tires?
Old Jan 13, 2010 | 06:18 PM
thanks I am hope so the car had a lot of problems when it went 12.7s....I have a 3600 stall PTC nitrous converter brazed fins and anti ballooning plates...
I have Nitto 555r on the back of my car now on the 18's and they are 12" wide...However when I get some more money I am going to get a set of Pro stars with MT ET Streets....
I also have to change out my gear in my Moser 12 bolt...i have a 4.11 in there now and I know it won't be enough on a nitrous pass with the TH350 so I think I am going to go with a 3.55
