Headers getting Cherry Red..need Help!!!
When it's rich it doesn't fully ignite and therefore runs alot cooler, cause all the gas isn't being burned and the whole process of combustion is kinda being smothered.
You want the combustion to be at that perfect ratio to where all the gas and all the air will burn..which in all reality is a tiny hair rich..a tad more gas than air. The reason I say that is cause an atmosphere(atmospheric pressure at sea level) is 14.7:1, the majic number with the NA setup is 12.8:1..part of that is due to the cars engine having vacuum. Forced Induction cars are different.
Combustion temperature!=exhaust temperature.
glowing headers are cause by a rich condition and unburnt fuel getting into the header and burning in the header.
glowing headers are cause by a lean condition and hot air is forced into the headers repeatedly to get hotter and hotter causing a glowing red header.
every post its always like this lol... either its both or someone needs to figure it out so every thread dont have both answers in each post lol. makes searching **** people off
