Stripped abs brake fitting...how to replace
Instead of reinstalling them the same way, I'd like to fix them if possible.
If someone has done this and can offer some advice I'd appreciate it.
I had the same problem cracking loose the ABS module flares too. I tried a flare wrench and it did not fit tight and tried to strip it out.
I then took a crows foot wrench, heated it up with a torch and closed it up a bit in a vice. It now fits the flare nut super snug and with a wratchet will crack the flare loose without a blemish.
I didn't want to do that but on the other hand I also don't want to deal with leaking brake lines if the flare doesn't work properly.
I recently re-designed my hard steel fuel line to work better with my true duals. That was big PITA too.
