Fueling issue, WTF?
So I'm going to look for the fuel pump relay and hope that is bad. What else could be preventing the pump from running? I want to examine all available options, before I cut the trap door into my car, because you know, the tank is now full! Guess I won't be dropping it out if it is the pump.
Has anyone had a 255lph walbro die instantly, while the car was running? This pump showed no signs of weakness, I look at the pressure gauge a few times daily while in my travels, still was showing 39psi or so at a constant speed and 43psi at WOT.
Once you get it out you will see it..can't really miss it honestly. That and there is no fuse on that Circuit..I havent found one anyways..it consists of the Command Wire from the PCM, the Ground, then a 12V in from a Fuseable Link on the Junction, then a 12V out to the Pump. You can also check for power by going to the back of the car, drivers side under the wheel well and look for some wiring being plugged into a connector on the body. There will be 2 plugs..one for the Brakes, the other for the FP. Check that with a Test Light and turn the Key on and off to see if it gets power.
Edit.. Here is a pic off of Rob's site..
I know a guy with a 1997 T/A, and his is in the Car..the Fuse Boxes are the same size from 1993-1997..and pretty much the same Fuses & Relays.
Alright well it wasn't anything factory related anyway. I remembered that there was a 20 amp fuse inline in the racetronix wiring. That is what blew, replaced that car fired right off.
