Last Question before the motor is out!
Old Jan 14, 2010 | 03:41 PM
boostedpower's Avatar
Default Last Question before the motor is out!
should i unbolt and remover the ecu through the bottom? or disconnect everything and there holders (the things that hold the wires in place) it seems like it would be easier to unbolt the ecu and take it out with the motor, I've basically already disconnected everything but they are stuck to the k-member
Old Jan 14, 2010 | 04:01 PM
RamAir95TA's Avatar
The engine wiring harness comes out. Have you disconnected everything off of the motor and pulled it up and out of the way?
Not sure if you know what you're looking at, but the ECU (PCM) is on the top passenger rear side of the engine compartment.
