I think im the fastest lt1 in fl
#42
if some one in fl is faster, than so be it.....it will just give me another goal to set.
im still on a stock comp, k member,a arms and im about ready to try a cold air kit for my 4150 t. right now its sucking hot engine air.
#43
Do you mean the black turbo LT4 vette? I saw one run high 9's in person at OSW, which sucks ***** as a track.
#44
I've seen a white with black hood camaro at orlando many times that is superchargerd, not sure if it's a procharger or a vortec, go high 9's, and he still has a stock intake mani, might have some nitrous on it too, don't remember.
#59
Could you turn that plate where both solenoids were faceing forward if you wanted?
no the bolt pattern is of set
BTW That lt1 you have is probably the fastest in a lot of states.
thanks
thanks
