Speed Density Air/Intake.....
Old Jan 17, 2010 | 07:25 AM
  #61
duh's Avatar
duh
I feel dumber for reading this
Old Jan 17, 2010 | 10:13 AM
  #62
Speedy's Avatar
Can anyone show me before and after track times proving ANY cold air intake improves ETs over stock intake?
Old Jan 17, 2010 | 10:42 AM
  #63
1 Craz28's Avatar
No doubt! If you really think about it, pulling damp, stinky, buggy, CO2'ed air from six inches of the ground might not be that good of an idea? The camaro's did come with it but the intake is behind the driver's side light!
Old Jan 17, 2010 | 03:52 PM
  #64
duh's Avatar
duh
They primary point to a "cold air" setup is air density as stated earlier. I'll try to make this simple for our younger crowd....
If you have an object with a specific volume......for this lets say an empty paint can......Inside this can there is a specific volume of space. Unless you alter the can you cannot change how much of something you can put in it. So fill this can with air. There is now a specific volume in that can, say 1.5 Liters. (this is just an example). Now since air is made up of Oxygen, Nitrogen, and some misc. crap you have a set amount of Oxygen available in this can at room temperature. But since Air is a compressible gas, drop the temperature to say 20 degrees from 70. You would see the level in this "paint can" drop down to say .75 Liters. That is because the air has become denser. Therefore you can squeeze more air into that same 1.5L can the lower the air temperature. And since an engine is truly just an air pump, the more air you put into it the better......So in retrospect, the colder the air you put into your engine the better. Stay away from heat and you will notice the car not only runs better but it will also improve fuel mileage.
Old Jan 17, 2010 | 04:20 PM
  #65
1 Craz28's Avatar
Actually, I believe highpressure (spun/disturbed) air is better for combustion and is just as important than air temp.......
Old Jan 17, 2010 | 04:26 PM
  #66
1 Craz28's Avatar
I guess someone turned the microwave off!
Old Jan 17, 2010 | 04:39 PM
  #67
duh's Avatar
duh
spinning the air does absolutely nothing for a dry manifold............if there were fuel in the intake manifold it may be worth something.....don't buy the hype
Old Jan 17, 2010 | 04:54 PM
  #68
1 Craz28's Avatar
That's how you create high pressure? Just like pulling air near the fresh air vents on a true cowl induction hood!
Old Jan 17, 2010 | 05:01 PM
  #69
jebcamaro's Avatar
I don`t have to read the Sunday morning funnies anymore in the newspaper. I can just log onto here and find what craziness is being posted by 1 craz28 and get my daily laugh. Dude you certainly live up to your name
Old Jan 17, 2010 | 05:05 PM
  #70
1 Craz28's Avatar
A yes Jeb! Victory is sweet. That's the way we roll out here in Va.! Where battles have been faught, the water is leaded, the animals and their diseases will eat you alive, and we have a local artillery range!
Our TAXES at worK!
Actually that first portion of my post was pertaining to MN's whoopasss on Texas!!!!!!!!!!!!!!!
Old Jan 17, 2010 | 05:50 PM
  #71
I8ASaleen's Avatar
Reality pales in comparison with your infinite knowledge.
Old Jan 17, 2010 | 06:12 PM
  #72
jebcamaro's Avatar
Were you a military experiment gone wrong? Do you wear aluminum foil on your head?
Old Jan 17, 2010 | 06:16 PM
  #73
duh's Avatar
duh
Actually a cowl hood works based on fluid dynamics. The same way an aircrafts wing works. The air going over the object has to move at a faster speed than the air going under it to arrive at the same point behind the object. This creates a high pressure area above the object. In the case of a cowl induction hood, the air comes up the hood then hits the windshield. This creates a low pressure area at the cowl (a lot like the bed of a pickup truck driving down the highway) This aids in getting fresh air to the engine. So what you are truly looking for is the low pressure area, not a high pressure anything......unless you're going forced induction, then blow it to the moon!
  #74
1 Craz28's Avatar
No just bored. And thinking of inventing the lead helmit.................
O' that's make sence. Low pressure is the key. Sea-level..........
Old Jan 17, 2010 | 11:02 PM
  #75
MasterTomos's Avatar
why the **** is this not locked yet???
lmao...post up them track times and maybe I'll order up a double helix super twin double adjustable HAI for myself...
and by the way...the only lS motor you'd outrun stock vs. stock would have to be in a dump truck or peterbuilt...
Old Jan 17, 2010 | 11:27 PM
  #76
camaroz28383's Avatar
http://i577.photobucket.com/albums/s...polarphone.jpg
Old Jan 18, 2010 | 12:53 AM
  #77
Speed Density's Avatar
hashtagBMW
1 Craz28
You have had a short vacation already and have also been warned about posting pointless threads that make zero sense. I am begining to think you are a normal person with a troll mentality and a soggy cheerios up top.
This is your last warning, post LEGITIMATE threads with ACTUAL topics/questions or your done here.
Tony.
By Brett Foote | 2026-06-04 05:00:17
