Need some info on ysi/ls1 pcm conversion
ok i upgraded to the LS1 conversion with the 24X setup from the EFI company... my question is this, am i able to still use my acceloronics low imp 86lb injector upgrade??? back in 2004 when i built the car the first time i bought a kit from jeff at acceloronics with the S trim blower... anyways since i did away with the stock LT1 pcm and opti is the LT1 low imp uprade kit compatible with my setup??? i didnt even think to ask cause i had to do so much over the last year or so with the car and wasnt even planning on getting the 24X kit until the end of this.... jake
i have no idea what an LT1 low imp upgrade kit is. but the pcm will need to be set for 86lb injectors or you will flood your engine within seconds of starting it. should not be a big deal because if you are doing the LS1 pcm conversion in the first place you should be planning on tuning it with HPTuners/EFIlive anyway.
