Stripped Power Steering!!!!
Old Jan 17, 2010 | 11:21 PM
SmartOJ's Avatar
Default Stripped Power Steering!!!!
i have a 96 z28. i noticed that my power steering pump was shaking while the engine is running. so i tried to tighten the pump mounting bolts and they are both stripped out.not the bolt but the aluminum in the accessory bracket is stripped.is there anyway to fix this?
Old Jan 18, 2010 | 12:48 AM
RamAir95TA's Avatar
Helicoil.
Old Jan 18, 2010 | 02:44 AM
the_merv's Avatar
Worst case re-tap it and get a bolt from lowes that is a hair bigger.
Old Jan 18, 2010 | 05:51 AM
madhatter's Avatar
10239875 is the part number for the bracket if you don't want to tap it, or if you can't find a used bracket.
Old Jan 18, 2010 | 12:11 PM
bigbusa1's Avatar
i'm taking the power steering off my 94 if the bracket is the same lmk
Old Jan 18, 2010 | 12:58 PM
the_merv's Avatar
It is the same.
Old Jan 19, 2010 | 01:55 AM
SmartOJ's Avatar
dont really want to take all that stuff apart to change brackets.just going to fix one i have. i tried to get the pressure line on the pump off and turning that nut with an open end wrench is extremely GAY!!! is the a tool to make it easier?
Old Jan 19, 2010 | 03:34 AM
RamAir95TA's Avatar
You need a line wrench. Using an open-ended wrench is a good way to strip it.
Old Jan 19, 2010 | 05:23 AM
biggriff's Avatar
i need a p/s pump...my pulley shakes like its bent? pm me if your getting rid of yours.. thanks
Old Jan 19, 2010 | 06:06 AM
SmartOJ's Avatar
undedrstandable.but im more so talking about the way u can only tun the nut lil by lil.i wanna get more longer turns o n it
Old Jan 19, 2010 | 04:07 PM
SmartOJ's Avatar
ttt......
Old Jan 19, 2010 | 04:23 PM
Jazz-LT1's Avatar
I usually loosen the pump from the bracket before removing the line usually. Give a little more room, but yes, it is extremely gay.
Old Jan 19, 2010 | 07:07 PM
kierstyn's Avatar
We used a bolt that was a little longer but the same size diameter in one and it caught some back threads I guess worked good!
Old Jan 19, 2010 | 08:29 PM
SmartOJ's Avatar
those mounting bolts ure dont have enough threads left once it goes thru the pump to fasten to the bracket good
Old Jan 20, 2010 | 04:58 PM
SmartOJ's Avatar
im going to try some longer bolts first. wat size bolt are they and wats the thread pitch
