Problem pulley!
Old Jan 19, 2010 | 07:25 PM
boostedpower's Avatar
Exclamation Problem pulley!
So I Have a problem getting this crank pulley off, My motor is off the car and it is spinning when I try to unbolt the pulley, how can i stop this from spinning and do i need a pulley puller to get this off?
here is a pic so you can see what I am talking about...
Old Jan 19, 2010 | 07:28 PM
1badzee's Avatar
The pulley is ready to come off.. You need a puller. That bolt in the center is for the crank hub.
Old Jan 19, 2010 | 07:40 PM
RamAir95TA's Avatar
You need a 3-toe puller.
Old Jan 19, 2010 | 07:59 PM
Thanks guys, I Just got back from Notsoadvancedautoparts well see if this does the trick!
Old Jan 19, 2010 | 10:07 PM
shbox's Avatar
Here is how you can use a puller when it won't come off:
http://shbox.com/1/pull_pulley.jpg
Old Jan 19, 2010 | 10:44 PM
SoxXpupPeT's Avatar
if your pulling the hub off the crank shaft then you have to remember to press against the bolt to pull the hub off. be sure to back out the bolt first
