2.75" vs. 3" catback
Old Jan 20, 2010 | 11:32 PM
ssbowtie1's Avatar
Default 2.75" vs. 3" catback
How much difference, if any, would there be on a bolt on lt1 with long tubes going into a 2.75" catback with a magnaflow muffler vs. a 3" catback with a magnaflow muffler?
I have a 2.75" catback now and I'm just trying to decide if its worth going for the 3" catback or not.
Old Jan 20, 2010 | 11:44 PM
SoxXpupPeT's Avatar
what would the price difference be for you ? the stock exhaust on these cars severely limit the power from the engine. if you had the choice of a 3.5" catback thatd be even better. or true duels for the best. but a 3" catback will give you more gains then a 2.75" one. id say do it.
Old Jan 21, 2010 | 12:16 AM
RamAir95TA's Avatar
The stock catback is 2.75". There's a reason most aftermarket cat-backs go to 3" and up.
Old Jan 21, 2010 | 01:34 AM
hitmanws6's Avatar
it will help a little bit but it wont be a huge night and day difference
Old Jan 21, 2010 | 01:55 AM
MasterTomos's Avatar
well if you plan on just having a bolt on only car, 2.75 is prolly enough, but with 3 inch you'd have more power, plus with a 3 inch you'd be good to go with many more modifications later if you want.
Old Jan 21, 2010 | 07:50 AM
TheDon619's Avatar
actually a full 3 in exhaust is a little over kill on bolt on motors, my buddy is running close to 900 hp on full 3 in exhaust and its still not limiting him, id say keep the 2.75 with the bolt ons to save the money sense you already got it installed. If you do head/cam.intake swaps then consider 3 in.
Old Jan 21, 2010 | 09:20 AM
happysem's Avatar
Don, I'm not sure where you got your info, but that sounds extreme.
I thought 3" was good for under 500hp, not sure of that number...but I'm pretty sure 900 is being choked.
Old Jan 21, 2010 | 10:45 AM
RamAir95TA's Avatar
I have no idea where some of you are getting your ideas from...
STOCK exhaust is 2.75". Most every cat-back available is 3" or larger for a reason. And why is exhaust usually the first recommended modification? Because it offers the most HP right out of the box than any other bolt-on modification by itself.
Yikes!
Old Jan 21, 2010 | 11:27 AM
Vicious95Z28's Avatar
Boy, my dual 3" setup must really be killing me. That must be why my car feels like such a terd, sheesh1
Old Jan 21, 2010 | 12:10 PM
ssbowtie1's Avatar
Has anyone actually put a stock car on a dyno then installed a 3" catback and compared results? Mine would be a bit different as I already have the magnaflow muffler but I'm looking for more convincing proof.
Old Jan 21, 2010 | 12:24 PM
StealthFormula's Avatar
"A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…"
taken from LT1engine.com
A bolt-on LT1 will make more than 310hp at the motor therefore a single 3" catback would be beneficial over a 2.75" system. If you ever plan to rip into the internals of the motor, the 2.75" system is going to be a big hinderance. Are you running the stock catback with a magnaflow muffler welded in? If so, simply jumping to an aftermarket 3" catback would net gains by being mandrel bent on top of being a larger diameter.
Old Jan 21, 2010 | 01:09 PM
SoxXpupPeT's Avatar
yup what he said
Old Jan 21, 2010 | 02:29 PM
Rob's Avatar
Rob
I still had the stock 2.75" exhaust on my 89 TTA when it was running 12.1. I had it dynoed the same weekend and it was 318/455 on a dynojet. Granted that was a turbo V6, it shows you can still make power with the stock exhaust.
Old Jan 21, 2010 | 03:57 PM
RamAir95TA's Avatar
Make power? Yes. Maximum power? No.
Old Jan 21, 2010 | 08:17 PM
of course you can still make power, the 2.75 won't keep you from makin power completely, it'll just hold it back some.
Old Jan 21, 2010 | 08:35 PM
RamAir95TA's Avatar
Think about this statement....
Old Jan 22, 2010 | 10:06 AM
RED94Z28's Avatar
lmfao hahahaha
Old Jan 22, 2010 | 07:03 PM
what's wrong with the statement? I know it's an obvious statement but that's what I was getting at...
Old Jan 22, 2010 | 07:07 PM
pillarpod's Avatar
nothing, great point
Old Jan 22, 2010 | 07:12 PM
amstech's Avatar
If catback, 3" Stainless or bust.
