Stock Crank Limitations
Old Jan 21, 2010 | 09:43 AM
ElkySS's Avatar
Default Stock Crank Limitations
i cant find a number. all i read is "it will handle alot""it is strong enough". thimgs like that. but at what rwhp does the stock crank become an issue? will it handle 500rwhp plus a 150 shot, assumimg all else is forged and correctly built? when is a forged crank actually necessary?
Old Jan 21, 2010 | 10:47 AM
RamAir95TA's Avatar
For a N/A application, the stock crank has seen upwards of 500+ whp. Personally though, I wouldn't put a spray of nitrous on top of that. Unfortunately there is no magic HP number on when it will fail.
When is a forged crank necessary? When you can't afford to rebuild another motor when the stock one breaks.
Old Jan 21, 2010 | 10:54 AM
AChotrod's Avatar
I dont know of a single stock crank failure reguarless of power. If that means anything to you. If someone else has please post up.
Old Jan 21, 2010 | 11:06 AM
TT632's Avatar
Thats an affirmative and I can't think of a single failure that Ive seen where a flexing stock crank causing another failure. I do have 2 aftermarket 4340 cranks that have cracks in them.
Old Jan 21, 2010 | 11:08 AM
OutlawZ's Avatar
RPM is usually a killer of cranks before power.....
I think the reason you haven't seen alot of stock crank failures is because not many ppl are using them much past 600 or so hp......
I mean if you use the stock crank you're pretty much limited to >360ci or so..... most want to stroke their motors to 383 or 396 so the stock crank is out...
Old Jan 21, 2010 | 11:25 AM
draggin97s10's Avatar
build it dont be scared we all blow something up at one time or another
Old Jan 21, 2010 | 11:31 AM
robsquikz28's Avatar
I know of someone with a stock bottom end pushing more than 550 to the tires!!! still goin strong!
Old Jan 21, 2010 | 11:32 AM
LS1 SPEED's Avatar
I have seen many at 600 or so with no failures, but its not that expensive for a forged crank to have no worries.
Lsx cranks we have been over 1000 rwhp with 0 issues.
Old Jan 21, 2010 | 01:12 PM
slomarao's Avatar
Ive read countless threads with guys pushing 750flywheel hp and some 800. Im not sure how they sleep at night but I wouldnt think twice pushing 550rw.
But your 500rw + the 150 shot maybe be walking on thin ice. Especially if your going to be doing it on a regular basis. 650-675rw is quite a bit for a cast crank in my mind.
What kind of rpm are we talking here?
Old Jan 21, 2010 | 01:21 PM
AChotrod's Avatar
I agree with outlaw, that alot of the big power guys are strokers, there for they ditched the stocker, but none the less I still dont know of a single factory crank letting go.
Old Jan 21, 2010 | 01:27 PM
suicidal racing's Avatar
there is no true figure to this seeing your crank could of been beat on its whole life and seen high rpms..or could of been babyed
now ive seen bbc stock cranks make over 1000hp,i had a 1969 327 2 bolt main engine and i only put trw pistons in it with arp **** and made around 750hp with 150 shot..ive read people taking gen 1 350s and going 900hp on stock cranks and blocks...theres the guy on here with the stock 6.0l making 1360hp on a stock crank an block with a turbo...the newer cranks are better forgeings from the 60s and early 70s..so could your crank take it yeah probley..how long..well you will only get that answer when you got rods out the side of the pan
Old Jan 21, 2010 | 02:11 PM
OutlawZ's Avatar
it comes down to "what can your wallet handle?????"
If you put a stock crank in it and wanna push 500,600, or 700 hp do it.... It PROBABLY will be fine....
but be forewarned that IF a crank lets go at speed it is going to take out EVERYTHING. It'll most likely crack the block, destroy the crank itself, rods will be twisted as ****, pistons are gone... so if you can handle a complete motor explosion and still sleep at night try it out...
Old Jan 21, 2010 | 02:28 PM
AChotrod's Avatar
^^^^that could happen to a forged crank too though. Truth is racing is rough on engines and you never know what could happen.
Old Jan 21, 2010 | 02:49 PM
ElkySS's Avatar
well its a daily driver and my only car. i was pushing the figures a bit just to make sure. im just trying to see if i can build a budget forged 355 and get away with that much power if i wanted to
Old Jan 21, 2010 | 04:44 PM
AChotrod's Avatar
I would say your good.
Old Jan 21, 2010 | 05:30 PM
I8ASaleen's Avatar
I don't think I could ever DD my T/A again; especially not when I get the engine built. I like to have too much fun with it and I know that equates to broken things all the time.
Old Jan 21, 2010 | 07:49 PM
Doughboy692's Avatar
A budget build 355ci engine that makes 500rwhp plus and daily drive it?
My car must be really be in left field, I have a 398 with all the best parts in it a set of afr 210 heads on it with extra work, Intake done by hand at Lingenfelter, the same cam that is in one of the fastest lt1 cars in the country (he is on this board if he wants to give you the specs he can post them but I am not going to), step headers with port plates and merge collectors,vacuum pump, low tension rings, lightweight everything, and just about every trick in the book, tuned on Ed Wrights dyno by Ed and I am just now getting to/past those kinds of numbers. If you dont mind sharing some info on how to do this with 355 cubic inches on a budget I will thow mine in a scrap bin and start over.
Thanks in advance for the help
Rob
Old Jan 21, 2010 | 09:48 PM
ElkySS's Avatar
uh. i said i was pushing the numbers. i was actually hoping for around 450 through a 6 speed with an Ai top end.
calm down a little man, it was just a simple question about how much the stock crank will handle. not trying to compete with anyone for knowledge here
p.s. Ai's web site lists a 355 that makes 1012rwhp with a turbo and GM heads
Old Jan 21, 2010 | 10:19 PM
No need for me to calm down I never got excited to start with. I just thought you had found something out there that works. I have personally seen a 383 lt1 Trans Am that puts 530 NA to the rollers and runs 9.9x @ approx 400 DA and to say it is done right is a understatement. Thats where I am trying to get to this winter. Any secrets that people will share to help me get there I am always willing to listen to them.
Big difference in what needs to be done to pack air in a cylinder with a turbo and trying to suck it in naturally. Just saying.
The stock crank in a lt1 is pretty tough just make sure you have it magged to ensure you are starting with a good part before machine work because 450 at the rollers is likely to be upwards of 550 at the flywheel.
Last edited by Doughboy692; Jan 21, 2010 at 10:26 PM. Reason: spelling, added to post
Old Jan 22, 2010 | 08:26 AM
ElkySS's Avatar
well im pretty sure that 530 was through an auto. and i believe thats an ai car too. it has tfs on it. im talking 6 speed. i dont think it would be too hard
