Steering shaft is off 180*, how to fix?
Old Jan 22, 2010 | 12:51 PM
porksoda's Avatar
Default Steering shaft is off 180*, how to fix?
Ok I replaced my rack a couple days ago and got an alignment today. Seems as though the steering wheel may have moved when I put it all back together and I didn't notice. Me and my buddy at Sears aligned it and the only way to get everything in spec was with the steering wheel all the way upside down. Here is my question. Can I just turn the wheels straight, disconnect the steering coupler, get in the car and turn the wheel right side up, then reconnect the steering coupler with it all clocked correctly? I hear the air bags may go off when you turn the wheel as its not connected to the rack so is that possible? Should I disconnect the battery when doing this?
Old Jan 22, 2010 | 12:53 PM
RamAir95TA's Avatar
You probably installed the steering linkage 180-out. Just disconnect it, turn the wheel 180 degrees, and reinstall it.
Old Jan 22, 2010 | 12:55 PM
deelong4002's Avatar
^^ just what i was going to say. Straighten your wheels out as best you can, and then disconnect the linkage, and go in and put your wheel where it should be, you should be able to reconnect the linkage. If not, you have something else wrong. But as long as you didnt move the steering wheel on its splines, this should be easy to fix.
Old Jan 22, 2010 | 12:59 PM
the_merv's Avatar
Yes..no you don't need to dis-connect the Battery.
Where in the hell did you hear that ****??..
Man that's got to be the best one I've seen in a while..
I want to meet whoever told you that...so I can kick em in the nuts..
Old Jan 22, 2010 | 02:56 PM
05HD's Avatar
Airbags aren't going to go off but you can quite easily break the SIR coil resulting in an airbag light and disabled system.
Old Jan 22, 2010 | 03:36 PM
porksoda's Avatar
Haha could be that I made that up but I swear I heard or read something about the air bag going off. Oh well who knows. I guess I'll just reclock the wheel and call it a day.
Old Jan 22, 2010 | 11:33 PM
1994formulalt1's Avatar
it says something when u take the plastic part off of the steering
Old Jan 23, 2010 | 03:31 PM
porksoda's Avatar
Looks like I will find out today after work.
Old Jan 23, 2010 | 03:55 PM
AChotrod's Avatar
You could also disconnect the battery then yellow wires/connector on the column if your worried about it
Old Jan 23, 2010 | 05:41 PM
I8ASaleen's Avatar
Or pull the airbag fuse
Old Jan 23, 2010 | 05:46 PM
1badzee's Avatar
Or just try out your luck..
Old Jan 23, 2010 | 06:53 PM
I8ASaleen's Avatar
You know this section isn't near as entertaining without a certain crazy member that quite possibly owns a Z28. All of these posts are related to people actually doing something
Old Jan 23, 2010 | 07:17 PM
1badzee's Avatar
The guy who invented the HAI?
Old Jan 24, 2010 | 02:10 AM
the_merv's Avatar
Lol..
Old Jan 24, 2010 | 09:46 AM
TheTransporter69's Avatar
What was the HAI? do you need that plastic piece that goes into the firewall? jw i can't get mine back in lol.
sorry for the hi jack
Old Jan 24, 2010 | 02:04 PM
porksoda's Avatar
Just as a reference for anybody...no I did not get killed with the airbag by turning the wheel with the linkage removed.
Old Jan 24, 2010 | 03:37 PM
the_merv's Avatar
Lol.. must've been like a moment of truth for you there..one wrong wire and
Old Jan 24, 2010 | 05:54 PM
Spartan7's Avatar
Did you make sure the SIR coil is aligned though?
Old Jan 24, 2010 | 06:29 PM
porksoda's Avatar
SIR coil?
Old Jan 25, 2010 | 12:32 AM
the_merv's Avatar
Why wouldn't it be aligned..all he did was straighten the wheel..
