Steering shaft is off 180*, how to fix?
I have a similar problem but the wheel is only off 45 degrees or so. I'm replacing the tie rod ends (Baer Trackers) so while I've got it apart I'll get the wheel straight and install the tie rods at the new correct length. I'll also be getting the car aligned again with a competition alignment.
