stahl?
Old Jan 22, 2010 | 09:49 PM
rutt71's Avatar
Default stahl?
I have a 95 firebird lt4 cam heads intake 58mm bbk 42lb injectors supercharged 8lbs of boost410 gears full built tranny wknd car not daily driver any ideas on what stahl I should run? 3600? Car is stripped to bear minumum on weight also
Old Jan 22, 2010 | 11:37 PM
Elliott's94Z's Avatar
"Stall" is the word you are looking for. Call up Dave at Yank and he will guide you in the right direction http://www.converter.cc/converters/street/GM/2/
Old Jan 23, 2010 | 10:39 AM
pillarpod's Avatar
if its not a dd i'd go with the 4000
Old Jan 23, 2010 | 12:13 PM
the_merv's Avatar
I'd go with a 3600..you can play with the Torque a little more..
Old Jan 23, 2010 | 01:24 PM
derekderek's Avatar
Just put a 5000rpm in there and be done with it!
