any ideas on my lt1 355?
ok just finish my lt1 355 its on a 94 firebird formula non t top, just whant to know what would be time on the track for those ho have built lt1s. the car is getting a tune after i breack in the engine.Any ideas what would be my rwhp after the tune?thanks OEM LT1 CRANK,EAGLE I BEAMS RODS,SRP PISTONS,CLEVITE BEARINGS,JE RINGS, MELLING HV OIL PUMP,STOCK LT1 TIMING CHAIN,COM CAMS 236/242 HYDRAULICT ROLLER CAM,58MM INTAKE,58MM TB,MID HEADER3"INCH Y PIPE,30LB SVO INJECTORS,1.6 ROLLER ROCKERS,7/16 ROCKER STUDS,ROLLER LIFTERS,PORT POLISH HEADS,DELEAT AC, SMALLER UNDER DRIVE PULLY.
