Oil out my dipstick tube normal?
i have oil spray out of my dipstick tube.. the stick itself is broken on the top. the tube steams a bit when car is fully warm too.. is this normal? or does it sound like who built the motor rings bad? or is that much spray/steam come out of that tube if its not sealed normal?
ya figured. lovely. its a forged 383 i traded for. they built it and traded it to me.. i just keep finding more and more wrong. guess i should pull this whole motor apart.
hashtagBMW
Does it come out at idle or under load?
Pull the dipstick out and the oil filler cap off, you should have 'some' smoke/moisture coming out because all engines have blow by. But if its a cho-cho train then you have an issue.
Do a compression/leakdown test if you can, that will pinpoint the issue.
its not really puffing, its constant steam coming out from what i see. oil doesnt come out unless i am driving, so its fine at idle but under load rpms is when it starts coming out
sweet. i havent been able to drive this car since i got it. runs like ****. i might as well pull motor and start over. this guy i got it from was terrible apparently
