Need some serious help and input on the LT1
Old Jan 31, 2010 | 07:37 AM
  #41
SixShooterCam's Avatar
Well my buddy is selling me a 9 inch rear end for 100 bucks just needs gears and a new posi... as for the tranny the guy that rebuilt my 4l60e said he would rebuild it when the time comes with a stage 2 vette heavy duty kit for rather cheap and he said he would eat the cost of a stall when I started putting more power into the car so I will be going with the yank ss3600...
ill be going with 1 7/8 kook headers and im doing true duals dumped before the axle... Yeh man I should be set, im alright at putting the block together its the timing is gonna be the hardest thing to do, not sure what kind of timing to go with
Old Jan 31, 2010 | 07:42 AM
  #42
marc97taws6's Avatar
More knowledgeable people will jump in as far as help for timing.
And for your stall with the use of nitrous, I would recommend bumping it up to an SS4000. Thats eventually what I am going to do. Should have done it the first time around
Old Jan 31, 2010 | 07:51 AM
  #43
damn does it make that much of a difference? for a 4000 stall... im kind of an idiot because I dont know really how the stall works I mean i know the concept but ive never driving a car with a stall... do you just the gas and the stall does the work on its own?
Old Jan 31, 2010 | 12:55 PM
  #44
kalebm22's Avatar
Restricted User
ide stick with the 3600 stall for nitrous in my opinion. if the 4k stall is looser than my 3600 then i think it would kill your shift extensions haha
Old Feb 2, 2010 | 02:53 AM
  #45
Eagle H-Beam Rods
Wiseco Forged Pistons
ARP Rod Bolts
.030 overbore
Balanced rotating assembly with stock crank
ARP Fasteners for bottom end
LE2 Heads
236/244 cam with a .592 lift
LS1 intake setup
58mm TB
Ported stock intake mani
42# inj
Yank 3600 stall
3.73 gears
1 7/8 Kooks race headers
150 shot (wet)
What do you think of that setup and how much HP and what E/T you think id get with that assuming I have Drag Radials on it
Old Feb 2, 2010 | 08:15 PM
  #46
kalebm22's Avatar
Restricted User
Originally Posted by SixShooterCam
Eagle H-Beam Rods
ARP Rod Bolts
.030 overbore
LE2 Heads
LS1 intake setup
58mm TB
42# inj
Yank 3600 stall
3.73 gears
150 shot (wet)
i would think that mid to high 11s would be pretty easy with enough traction and a good tune. then that 150 shot should get in the 10s somewhere, im not exactly sure how much the nitrous will help you since i havnt had any real experiance with it. sounds like an excellent setup though!
Old Feb 3, 2010 | 12:56 AM
  #47
Oh yeah I was gonna be happy being in the high 11s so if I break 10s then it was a well 10k spent im starting on this probably monday
Old Feb 3, 2010 | 01:10 AM
  #48
kalebm22's Avatar
Restricted User
ya, i think you can do that pretty easily. i am starting a build this week also and the only difference is mine is goin to be a 383 and with 3.90 gears. lloyd specd the exact same cam for my engine also. so keep us posted on how things are going with your build and good luck!
Old Feb 3, 2010 | 02:14 AM
  #49
Thanks bro and same goes for you... that 383 will be bitchin... I was going the 383 route but elected to save money on the crank and for the power my stock one would be good enough for the load.... the stock cranks are somewhat stronger than after market cast cranks lol
Old Feb 3, 2010 | 03:06 AM
  #50
kalebm22's Avatar
Restricted User
yea, you made an excellent choice on keeping the stock crank. clayton racing engines has a forged 383 kit that puts my compresison right where i wanted it so i just couldnt pass it up.
Old Feb 3, 2010 | 03:52 AM
  #51
very nice... Keep us updated
Old Feb 4, 2010 | 05:57 AM
  #52
So the oil pan was dented and screwed off the motor... so what pan and pump should I go with, keep in mind this will be my DD for the most part so I need something reliable
Old Feb 4, 2010 | 01:01 PM
  #53
ktraver97ss's Avatar
I like the direction your build is going! Very similar to my plans for the SS. I wont be doing the bore and am going with a D60 but Im excited to see what kinda power u put down with that setup. Ill be waiting
I hope to get my trans and rearend done this summer and pull the motor and do the rest next winter.
Old Feb 4, 2010 | 10:04 PM
  #54
yeah im excited also man... im working with some guys who are really helping me out like Sean at Topgear motorsports and Lloyd Elliot... they are excellent so far.
Im just nervous about my engine bay because I want to clean it up so badly but im gonna wait for the new motor to come back fromthe shop and I have to send out the heads to lloyd... im ordering my suspension from Brad at UMI maybe monday or tuesday of next week also
I just dont know what kind of oil pan and oil pump to put in this thing? LS6 oil pump?
