Winter mods..What are you up to??
Old Jan 28, 2010 | 12:12 AM
riceburnerZ28's Avatar
My car has been in the garage for 3 weeks now getting a clutch upgrade. I've been trying to bleed the clutch master for a couple days now and still not able to get the damn thing into gear. I've been doing mostly repairs but new mods won't come until early spring.
Old Jan 28, 2010 | 12:24 AM
zlicious94's Avatar
Strano springs,hawk pads, and some motive 4.10's!
Old Jan 28, 2010 | 12:26 AM
sworaz's Avatar
Nawwz....jk HSW wet kit that I just got today Nice to have a couple months to do a through install.
Also have to tackle a stupid oil pan gasket leak
Torque Fiend's Avatar
wish I had some power mods, but I'm just cleaning up the bay.
Old Jan 28, 2010 | 12:37 AM
robsquikz28's Avatar
NOthing, im broke as always and own a turd.
Old Jan 28, 2010 | 02:06 AM
WhiteHot's Avatar
Gotta replace some rod bearings to fix the not so yummy knock. Gonna check everything out and keep stock what I can in the bottom end to save some cash. Wanna do the LE2's, put my LT's on, figure out what broke in my clutch(gotta mash it to the floor to keep from grinding) and polish up my fart cans.
Old Jan 28, 2010 | 02:18 AM
CARFREAKS's Avatar
Default Everything
I just bought a forged 383 crank, a Turbo Cam, a 76 mm turbonetics turbo, some -10 fuel lines a A1000 pump and ragulators. I picked up my Tail Blow off valve and waste gate today. And waiting for my 6 pt cage to get finished.
Yes I'm in a place that snows so it gives me time to work on the car... Now I need to save up more $$ For more goodies
Old Jan 28, 2010 | 03:03 AM
marc97taws6's Avatar
Selling it and buying an LS1
Gotcha!
-Plans in sig
Old Jan 28, 2010 | 04:30 AM
WhitePhoenix99's Avatar
Best Idea Yet!
Old Jan 28, 2010 | 04:50 AM
Snake_Skinner's Avatar
Mines my DD so no car cover for her yet, but already bought:
Pacesetter LT's
3' ory
Pioneer DEH-P6800MP HU w/ ipod connector and PAC SWI-PS
ED 700's(or whatever) for the sail panels
18in AR Rebels staggered width wrapped with Nitto 555r's
and slowly still buying.....
Old Jan 28, 2010 | 07:20 AM
dlk1950's Avatar
Had LE1 heads & new cam installed,picked up 51 rwhp,going to take 10 bolt apart to see if I can get another season out of it.Local track don't open till april. Going to be a long wait till I get some passes in.
Old Jan 28, 2010 | 07:42 AM
  #32
FASTFATBOY's Avatar
New pistons and rings, port intake, swap elbow and monoblade for a 4 hole and a carb hat, looser converter, re-tune, remove exhaust for da shootout, possibly manual brakes and Kirkey seats. New hood if I cant get under this one(it will on paper...but...ya know how that goes). Looking for some low(er) 10's on pumpgas.
Old Jan 28, 2010 | 08:17 AM
  #33
YSILT1's Avatar
Here is a list of everything I am doing. Trickflow/ TEA ported heads, Vic. Jr Intake, Edelbrock Elbow, FLP 90mm TB, Solid Roller Cam, EFI Connection LS1 ECM, Spec Stage 3+ clutch, Huge Bumper Mounted Air to Water Intercooler on a Burkhart Bumper Support, Burkhart Ice Tank with sumped water pump, Wolfe 6-point cage, New upholstered seats, headliner, door panal, visors, carpet, shift boot, consul lid all done in suede, dyanmat full interior, new sound system with 6litereater double din dash bezel.
I am hoping on getting this all finished by March. Here is a pic of the engine finished.
[IMG]https://ls1tech.com/forums/picture.php?albumid=9961&pictureid=41076
[/IMG]
Old Jan 28, 2010 | 08:24 AM
  #34
TheTransporter69's Avatar
Full exhaust, tune, and a few other minor things
Old Jan 28, 2010 | 08:37 AM
  #35
LS1 SPEED's Avatar
nothing too crazy
I had planned a 24x conversion, but put that on hold for now.
-new EWP since mine starting leaking from the flange where the actual motor seats
-LS1 lid swap with a FTP 98MM lid
-Chrs1313 Ram Air kit
-UMI CM chassis mount TA : Black
-Kirkeys ( sold Corbeau Forza's )
-new carpet
-graphite interior panels
-going with a dual bottle mount in the trunk
-Nitrous Outlet progressive controller
-ATI alum dampner ( 4#'s lighter then ASP )
-Yank SS3600 non lockup( SS4000 was too loose and no lockup saved 6#'s)
* 2 above mods took 10#'s off the crank
-FLT Level 7 ( Level 4 was taking a beating at my level )
-Hoosier Drags radials ( 10#'s lighter each and seem to work as well or better then M/T )
-changing up the rims ( not sure what yet )
-some other weight reduction stuff
-VFN bolt-on Sunoco hood
think that's it
Old Jan 28, 2010 | 08:40 AM
  #36
JasonShort's Avatar
Moderator
I'm finishing up a front mount single turbo build, changing from a steel flywheel Street Twin to an aluminum flywheel Street Twin, and the EFI connection LS1 PCM conversion.
Old Jan 28, 2010 | 08:43 AM
  #37
LS1 SPEED's Avatar
another Turbo LTx ...someday. someday
Old Jan 28, 2010 | 08:48 AM
  #38
bigwill12187's Avatar
Mines is still sleeping too. I have to weld in new patches because I had some rust holes, Took the tranny out doing new slave and going to do new master as well. Paint the underbody with rust bullet, subframes new exhaust and wheels almost done. Im hopping that I can be done by the end of feb. We will see what happens.
Old Jan 28, 2010 | 09:12 AM
  #39
kgkern01's Avatar
My plans are to pull my old motor, clean up engine bay, hiding wires, fuse box and fuel lines, repaint. Get my headers re-coated, polish alternator and accy bracket, powdercoat intake and shock tower brace. Get front bumper cover repainted.
As far as engine goes, custom 226/226 110 cam on 'new' 53k shortblock, with probably 21* TFS heads. Either 3.73 gears or new wheels.
Old Jan 28, 2010 | 09:14 AM
  #40
ks my ss's Avatar
actually working on the car again LOL
