Winter mods..What are you up to??
Old Jan 27, 2010 | 09:08 PM
AChotrod's Avatar
Default Winter mods..What are you up to??
Well is boring as hell and freezing cold out, so might as well talk about what the winter mods are, and whats going on with the cars.
My car is currently sleeping in the garage under the covers. But I got a crap load of stuff here or on the way then the work begins.
New rear Race Stars drag rims (that fit stock brakes without gringing them down)
new rear calipers
1" Hotchkis lowering springs for the rear
UMI drag bar
N20 outlet Plate kit, and all the goodies to go with it
Nano system
stand alone fuel system
Im also looking to do a 6point and some weight loss.
What are you all up to????? I know some of you have some killer stuff goin on.
Old Jan 27, 2010 | 09:13 PM
pillarpod's Avatar
mine is sleeping as well, my winter mods are....saving the cash up for them for this spring so i can pop that stuff in
Old Jan 27, 2010 | 09:14 PM
Colin91Z's Avatar
Some sweet chrome valve covers, a can of octane booster, and a new HAI kit from ebay
Seriously though...
No n2o for me, looking to gain a few ponies NA though
Also a little more weight reduction and likely a 6-pt. Gonna try to make my raceweight right on the 3400lb min for the shootout.
Perhaps a new flywheel/clutch too, as I'm still running the factory flywheel and my clutch is several years old now.
Old Jan 27, 2010 | 09:28 PM
1badzee's Avatar
Car is on a strict diet. Aiming for 2800 raceweight
Old Jan 27, 2010 | 09:39 PM
AChotrod's Avatar
what did you buy a miata????
I got a few more ponies NA with my cam swap in Nov, but didnt get any testing in.
I dont think the HAI is legal for the shootout, better check with Kyle and Tony.
Old Jan 27, 2010 | 09:43 PM
97camaross's Avatar
Its not much but 1.6 RR, LT4 springs, Trick flow hardened pushrods, 4.10 gears, full spool, LCA Relocation brackets, PHB, (If the funds are available T/A, T/A Relocation, and Slicks and Skinnys)
Hoping for the 12s
airfix's Avatar
Here's my list, I got lot's of work to do in the next 2 months. Braided Fuel line conversion, Wolfe 6pt roll bar, Sparco Steering wheel, Battery relocation, nitrous outlet plate kit with all the goodies, Bigger LE cam, Mcleod twin disc, mcleod bellhousing, jerry bickel chromoly DS, Moser 9" 35 spline with spool, Strange rear drag brakes, umi torque arm with loop, Adjustable panhard bar, bmr adjustable lca's, qa1 fron and rear 12 ways front 300lb spring, 3inch true duals, 28" et streets, umi 3 point sfcs, bmr xtreme drag bar, upper and lower umi a arms, umi k frame, egr delete, front !swaybar, sjm abs delete, solid motor mounts, cruise control delete, minor weight reduction. I'm probably missing a lot of stuff but you guys get the idea.
Old Jan 27, 2010 | 09:47 PM
Colin91Z's Avatar
That would be a big negative on the miata
I feel your pain, I switched from 17"s to draglites w/bias plys, and added Strange SAs on the front...and then my last trackday got rained out
So I have no idea what the car is capable of right now
Spring can't come quick enough.
Old Jan 27, 2010 | 09:53 PM
Puck's Avatar
Whats winter?? :p
My speed shop currently has my AFRs and are milling and flow benching them, and then I will be sending the flow sheet to Llyod to spec me a nasty HR and his recommendation for springs(probably patriot golds, but we'll see).
I'm doing a before and after flow bench out of curiosity to see how much a mill will affect the flow. Tony Mamo said the loss in flow from a drop of ~5ccs will be outweighed by the gain in compression, but I am just curious . I will be dropping them from 67 to 60-62ccs - I told them 62cc's are my goal but if they look good to go for another 2ccs to just go for it and get them to 60.
From there who knows - I've changed up this build three times and I haven't even taken the original H/C engine out from the car . I was going to reuse stuff from it but I ended up with a whole new engine so I'm probably gonna carb it with a small single plane and throw it in an rx7 or something...was good for mid 11s in my mild z28 so would be fun to see what it'll do in a tin can with a bigger stall and more gear .
Old Jan 27, 2010 | 10:01 PM
charlie97z28's Avatar
got the trans in with the 3500 stall. headers,gears,panhard,springs, are on the way lca's are in, m/t's are in. The nitrous kit is half way done just a few wires and run the feed line and get my switches where i want them. and that should do me till the after taxes come in to start the rear end and 383 build.
Old Jan 27, 2010 | 10:04 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
steering wheel...that's it!
Old Jan 27, 2010 | 10:05 PM
thomas89xj's Avatar
383, le3 heads/cam, tpis 58mm, draglights, 275 mt's, nx kit, diet, built t56, spec flywheel & 3+ clutch, t/a & relocation, kooks lt's, 3 1/2 true duals, battery relocation, polly mounts, manual rack, abs! w/ LL, egr/air!, new brakes, pro 5.0, i may have left something out? and ya stock 10 bolt with stock gear..........
Old Jan 27, 2010 | 10:07 PM
duh's Avatar
duh
Gathering money to get the LT's coated locally, then maybe get a catback to go with it.....oh and get a motor and trans to start working on. Already have one block, but may get rid of it if I get a complete engine......so I may have some parts for sale, but I really wanna build a trans again and see what I can do with it . Then I might even have a 700R4 for ya Mike
Old Jan 27, 2010 | 10:58 PM
SoxXpupPeT's Avatar
saving up for long tubes and true duel 3" out the back. also i want to start up an 8.8 build
Old Jan 27, 2010 | 11:00 PM
Big D Mcgee's Avatar
Trying to finsh my Tbucket..... Just got gauges to do and finish up on the plumbing of my fuel lines from custom tank. Expecting a bonus soon so I thinking a cc306 cam and spring upgrade will happen if everything goes as planned.
Just got a 93' Formula. Everything is in need of attention. Will try to get in solid running shape before winter is out and spring is in.
69' C10 is about to be primed for the first time since all the body work is now done. Fresh 350 is sitting on the stand waiting to go in as soon as I get her painted....
Too many projects and not enough time. Been working every fuckn weekend this year...
Old Jan 27, 2010 | 11:27 PM
strokin93z's Avatar
I'm in the exact same boat! I had just got Prostars, 373s, shocks, and raised shift points. Then our last week of the track being open was rained out too.. So now i'm just taking weight out of the car.
Old Jan 27, 2010 | 11:46 PM
BizZzatch350's Avatar
Moderator
It should be part it out but it'll be nothing, T56 and a LS1 PCM in the spring.
Old Jan 27, 2010 | 11:49 PM
JB_97ws6TA's Avatar
383 and a t56 swap
Old Jan 28, 2010 | 12:07 AM
SS MPSTR's Avatar
6pt CM rollbar, Coan TH400/transbrake/8" 5000rpm converter, Turbo Action shifter, 24x EFI Connection ignition, race seats, a new tune and 15x10 prostars with a 28x10.5 ET Street tire.
Old Jan 28, 2010 | 12:08 AM
SS MPSTR's Avatar
Originally Posted by JB_97ws6TA
383 and a t56 swap
I'll have a T56 for sale soon. Interested?
