VATS question
Old Jan 30, 2010 | 01:01 PM
ssbowtie1's Avatar
Default VATS question
If I put steering column "A" in car "B" I need to install a resistor to bypass VATS using the resistor value from the original key "B" correct?
Old Jan 30, 2010 | 03:09 PM
RamAir95TA's Avatar
Yawp.
Old Jan 30, 2010 | 03:28 PM
shbox's Avatar
...or get a key cut with the profile of key A and the pellet resistance of key B. If you are wildly lucky (1 in 15 chance), the keys may have the same pellet value. Measure to see.
