whont start help plz?
Thaks.
As for not starting, is it just cranking and cranking but not starting, is it sputtering but not running, or what?
Try this. Take a spark plug wire off and hold the end close to your header/manifold and have a friend turn the engine over....if a spark arcs to the manifold then its not ignition because if it was getting fuel and even a couple cylinders were firing it would still sputter a little. If there is NO arc, it could be your opti, your coil, or your PCM.
When you turn your key on (not turning it over, just on) do you hear the fuel pump? It should be a whine coming from the trunk area for about a second or two after you turn the key to the "ON" position...if you hear that then the pump is working. If you dont then your fuel pump may be out. If the pump IS working, check the filter to make sure its not clogged, etc.
Just because a plug is firing doesn't mean it's firing at the right time, so you can't use that method.
First things first. You need to figure out why it overheated.
Also, check your fuel pressure. Often a spontaneous no-start condition can be cause by a bad fuel pump (fairly common). Pick up a fuel pressure gauge and run some simple diagnostics (do a search). Just because you can hear the pump does not mean it is putting out ample fuel pressure.
and about the staring problem i guess i have to get a pre tune, breack in the engine and then get a full tune, but anyways the car runs and starts good, thanks for your help bro
about my typing, i know i need typing lessons lol, i was one of those kid that never pay attention in school, but on cars diferent story. If it wasen't for my wife i wodent never walk the stage lol. Hows my typing on this reply? better? Hey thanks againd.
