Double Roller Timing Set For 93 LT1
Like Rob also mentioned, if you installed an aftermarket cam, the cam snout is already drilled for the longer shaft of the vented optispark, but the cam gear is the problem.
I should also point out that a gear drive setup is out of the question as well as it will drive the knock sensor absolutely crazy.
From an old post of mine: "If running an EWP, my favorite is the Cloyes 3157, which is the same as the GM LT4 ED minus the WP drive gear, AND it's a tighter fit than the GM ED. It's every bit as strong as the 3145 double roller and guarantees no interference and required grinding on the front of the block. The roller pins are the weak points in these chains and the double roller offers no advantage there."
Back to the other part of my post: The stock chain is not a bad choice. They don't have a history of breaking in performance builds.
In fact there's less need to rev the motor out in each gear since the nitrous moves the torque and power peaks so much lower. A motor putting out 600 hp with nitrous is going to be SO much easier on the entire valvetrain than one doing 600 hp NA.
BTW, is there a replacement for that plastic drive thing that sits in the place of the traditional distributor? The one that drives your oil pump.
