Double Roller Timing Set For 93 LT1
Old Jan 31, 2010 | 03:02 AM
93Z2871805's Avatar
Veteran: Air Force
Default Double Roller Timing Set For 93 LT1
I have been searching through all the timing set posts and even though I found some good info, none answered my question straight forward. I've got a single roller timing set in my motor now (Cloyes billet) but I wanted to change over to a double roller billet set. I understand it may be overkill, but IMO, it's overkill in a department that's worth it. I was wondering if I need to get a timing cover for the newer LTX with the crank sensor to fit one or can I use the one that came on the 93? If so what's a good part number? I don't want to make it complicated, I just want it to go together smoothly, with a double roller set. I'm planning on ALOT of N2O and don't want to risk having my valves kiss my pistons over a broken timing chain.
Thanks
Old Jan 31, 2010 | 03:36 AM
RamAir95TA's Avatar
Upgrading to a double roller requires you to upgrade to the vented optispark setup as well, so not only will you need the timing cover but a new camshaft (for the longer pin), new optispark, vacuum hoses, electrical harness, and an electric water pump (you cannot retain the OEM water pump drive with a double-roller).
Old Jan 31, 2010 | 07:28 AM
Elliott's94Z's Avatar
Don't waste the $$$
Old Jan 31, 2010 | 07:39 AM
SixShooterCam's Avatar
whats a good timing setup?
Old Jan 31, 2010 | 10:46 AM
4SFEDZ's Avatar
can you just change the pin?
Old Jan 31, 2010 | 11:25 AM
BizZzatch350's Avatar
Moderator
Need to change the opti as well to the 95+ style and then you would need to change the timing cover also.
Old Jan 31, 2010 | 11:51 AM
RamAir95TA's Avatar
Good luck getting the pin out while the cam is still in the car.
Old Jan 31, 2010 | 12:36 PM
94Z28rag's Avatar
Just pull the pin out with your teeth. It's not rocket science.
Old Jan 31, 2010 | 12:53 PM
shbox's Avatar
Not if it has the stock cam. The hole in the nose of the cam is not big enough to accomodate the vented opti drive.
Old Jan 31, 2010 | 01:45 PM
4SFEDZ's Avatar
right i know all the other stuff required, but i want to do the conversion but dont wanna have to get a new cam, my cam is out but havent tried to get the pin out, is it possible? its not a stock cam, and where can i get the longer pin?
Old Jan 31, 2010 | 01:54 PM
93Z2871805's Avatar
Veteran: Air Force
The motor's not in the car and is nowhere close to stock (except the block and timing cover). About how much deeper is the 95+ timing chain cover than the 92-94? Is it like a 1/4 in or is it something that could possibly be clearanced to fit the larger timing set? If not I guess I'm just sticking with the single roller. Honestly this isn't my first time with a Chevy V8 (Rat or Mouse), but it is my first go at an LTX, so the Gen II specific stuff is a little new for me.
Also, I just looked at the timing set I ordered, it's a Lunati 93094, not billet, and a single keyway. I think I'm going to swap that out for a billet set with 3 keyways, any ideas as far as part #s that are proven for LTX applications?
Old Jan 31, 2010 | 02:09 PM
RamAir95TA's Avatar
You need a cam with the drilled cam snout (like Rob mentioned). It's not just the pin that is the difference - it's the cam itself.
Originally Posted by 93Z2871805
The motor's not in the car and is nowhere close to stock (except the block and timing cover). About how much deeper is the 95+ timing chain cover than the 92-94? Is it like a 1/4 in or is it something that could possibly be clearanced to fit the larger timing set? Honestly this isn't my first time with a Chevy V8 (Rat or Mouse), but it is my first go at an LTX, so the Gen II specific stuff is a little new for me.
You need the 95+ timing cover because of the opti setup, not because of the timing chain.
Old Jan 31, 2010 | 02:16 PM
shbox's Avatar
Most any aftermarket cam is already going to have the large hole in the snout (so it will be compatible with all LT1 years). Take the cam to a machine shop and have them change it out. That is your safest bet.
Old Jan 31, 2010 | 02:22 PM
93Z2871805's Avatar
Veteran: Air Force
That's what I'm wondering though, I don't want to switch opti's or the cover, I'd just like to swap the chain.
Old Jan 31, 2010 | 02:24 PM
93Z2871805's Avatar
Veteran: Air Force
Any ideas?
Old Jan 31, 2010 | 02:29 PM
RamAir95TA's Avatar
Right, I get that. But you can NOT upgrade to a double roller without switching to a vented optispark and 95+ timing cover. You also will need an electric water pump. It is not a straightforward swap whatsoever.
Old Jan 31, 2010 | 02:52 PM
93Z2871805's Avatar
Veteran: Air Force
Right, I get that. But you can NOT upgrade to a double roller without switching to a vented optispark and 95+ timing cover. You also will need an electric water pump. It i not a straightforward swap whatsoever.
Alright, I actually have not even seen the 95+ timing and opti setup, I was just wondering what it would take to work. It sounds like more than I would want to do. Do you have any suggestions for a single roller set? Like as far as what you know works real well on LTX motors? My gen I 406ci had a gear drive in it so I didn't have to worry too much even with the dual stage setup on it.
Old Jan 31, 2010 | 03:25 PM
93Z2871805's Avatar
Veteran: Air Force
^^^ Only one problem, I have the 93 style, I just want a stronger setup without converting anything like my MSD opti, or the cam I just put in.
Old Jan 31, 2010 | 03:27 PM
355TurboLT1's Avatar
Yeah just saw that. Not sure if the gen 1 timing set is supported by any aftermarket companies. I have never seen one.
Old Jan 31, 2010 | 03:31 PM
93Z2871805's Avatar
Veteran: Air Force
You think a timing setup from an 85-up hyd roller SBC would work on an early LTX?
