Vacuum??
Old Feb 1, 2010 | 02:00 PM
94_lt1_4mula's Avatar
Default Vacuum??
hello,
i am wondering if the top throttle body hose connecting to the valve cover(is supposed to have alot of vacuum). even after after higher rpm, there is still none. or do i ignore this and just put a breather filter on the both.
Thank You
Andrew
Old Feb 1, 2010 | 02:52 PM
CRAZZ28's Avatar
Put a breather filter on the valve cover and plug the throttle body port.
Old Feb 1, 2010 | 03:18 PM
shbox's Avatar
No, it is not supposed to have vacuum on it. It is the fresh air supply from the TB to the valve cover and crankcase.
