383 build
Old Feb 2, 2010 | 12:02 AM
Quasar94Z28's Avatar
Default 383 build
so i just wanna know what kinda numbers you guys think this will put down when i drop it in...it has an eagle crank, ealge rods, srp forged pistons, 1.6 rr's, melling hv oil pump,gm hd timing set,gm847 cam,new lifters,ported lt1 castings,comp springs,new valves,updated vented opti and timing cover,ported intake, lucas 42lb injectors, LT's, BBK 58MM TB and 7 liter oil pan.
This is going through a Yank 3600 stall thanks for any replies.
Old Feb 2, 2010 | 02:08 AM
daves94formula's Avatar
http://www.youtube.com/watch?v=vQQ36susmFE
this one did 403/371
the main things are going to be compression, tune, head flow and just how much your going to lose through your stall.
so im going to shoot for the 390-400 mark for you
Old Feb 2, 2010 | 02:11 AM
popo8's Avatar
my first 383, with a half *** build from a guy named ERIC PARISH (con artist) made 323 to the wheels without boost. but after It came apart we figured compression was about 7.5:1
Old Feb 2, 2010 | 09:42 AM
it should be around 10.5.1
Old Feb 2, 2010 | 10:51 AM
slomarao's Avatar
who did the heads? How much work is in them?
Old Feb 2, 2010 | 11:01 AM
99blancoSS's Avatar
Power is made in the top end. What heads are you using?
Old Feb 2, 2010 | 11:08 AM
RamAir95TA's Avatar
7 liter oil pan?! What compression? What rear-end?
THIS = FTW.
Old Feb 2, 2010 | 09:19 PM
the heads are just stock and opened up I know I need LE3's but I don't have the money right now cuz I need to support the power that it will have right now.
Should I not get that big of an oil pan? Or, what would you guys suggest?
Old Feb 3, 2010 | 02:33 AM
RamAir95TA's Avatar
A 7-quart oil pan will work fine. More oil capacity = lower oil temps.
You still need to answer the "what compression" and "what rear end" questions.
Old Feb 4, 2010 | 12:17 AM
should be around 10.5. The rear end is stock. (3.23's) That is my next purchase...what should I get?
Old Feb 4, 2010 | 08:22 AM
slomarao's Avatar
3.73 gears.
Old Feb 4, 2010 | 12:32 PM
RamAir95TA's Avatar
You might want to consider bumping up your static compression. With that cam you will be able to run a much higher static compression to pull your dynamic up a bit higher. If you're building a 383, no reason to not take advantage of an increase in compression. 10.5:1 is stock. You could easily eclipse 12:1 to tighten up your quench a bit more and give you a healthy increase in power too.
Old Feb 6, 2010 | 02:12 AM
yeah, the compression should def be higher. What oil pan are you using? I don't really wanna spend 500-700 on a bullit one or anything...so any suggestions would be great
Old Feb 6, 2010 | 01:10 PM
RamAir95TA's Avatar
I am using the Canton 242T. I think they run for around $300 or so.
Old Feb 6, 2010 | 06:55 PM
97Z28SS's Avatar
So how much rwhp/rwtq for a 12:1 383, LE3 heads & ported intake, 847 cam, EWP, 58mm tb, LS1 lid, Pacesetter LT's, 3" true duals, m6 and a S60 rear?
Old Feb 7, 2010 | 01:54 PM
kierstyn's Avatar
Now you are getting the idea but do you already have the 847 cam if not get a custom grind when you order the heads. With this I would say closer to the 450hp range but you will also have room for a big shot of nitrous!
Old Feb 7, 2010 | 02:21 PM
fuel's Avatar
my car was the same as what your thing about...i did 380wrhp....with a 242, 248, 584 lift cam
Old Feb 7, 2010 | 07:17 PM
97Z28SS's Avatar
When I spoke to Lloyd about my setup and told him that I had the 847 but was willing to go with a custom grind or an LE4 he told me to stick with the 847 since my car is basically a DD with ocassional test n tune drag racing. He said my car would be more DD friendly with the 847 cam than the LE4 so that's why I kept it, I will also be adding a 150 shot on top of it.
Old Feb 7, 2010 | 07:49 PM
kalebm22's Avatar
Restricted User
wow those numbers are really low for that big of a cam/ head package. ive seen le2 heads and 503 cammed cars put down 385 through an auto. how does urs do at the track?
