Eagle 4340 Forged cranks
Any additional machining the Eagle will need and the substantial likelihood it will be hard to balance mean in actual use Eagle is NOT the least expensive route to take.
i have a 4340 eagle crank and h deam rods. and running a 300 shot. 9.51 1/4 mile 6.01 1/8 mile i think its a decent product for a 800 hp motor. but if you can get a lunati for 600 i say do it...
It is not the horsepower rating you should be looking at - most of the forged cranks are good to four digit horsepower numbers that 99% of us will never reach. You need to be willing to spend the extra for a proper checking and machining.
The eagle usually takes more in machining costs then a higher end crank like compstar, but regardless of the brand you need to have it machined and balanced with your parts.
This keeps the price down but maintains better quality then a pure overseas crank, and many maufacturers follow this same path.
Like mentioned, as long as you go forged and have it machined and assembled properly you will be fine.
. I hope you are doing a half fill for cheap insurance.I SERIOUSLY considered selling my 0 miles fully forged/half filled 383 and going with a 408 since I will only be NA and my shortblock was built for big hits of nitrous so will be overkill for my all motor HR setup that probably won't break 600 flywheel.
Lack of patience, less funding then when I started, and the crappy market for selling made me decide to just keep it, at least for now.
Either way your project will be an epic build to follow, and a learning experience whether it works out or not
