LT1 Timing change swap w/electric pump?
I am going to have a cam swap done this spring on my 1996 Z28 and I am getting my parts together. I already have an electric water pump, so I am looking for a roller timing chain (other than the expensive LT4) as a replacement. As I understand, you can use a standard SBC roller timing chain, if you have an electric water pump. I am just checking to see if the one listed in the link below is the correct one?
http://www.summitracing.com/parts/CLO-9-3145/
Thanks!
Thanks!
