carb conversion questions about electronic
Old Feb 14, 2010 | 02:35 PM
suicidal racing's Avatar
Default carb conversion questions about electronic
alright looks like my opti is craping out and its only going to cost me about 500$ more to convert to the carb deal..i got a list of parts already..just have some questions about the electronic...im wondering if anyone has any one ever used the stock fuel pump and just hooked it up as a toggle deal??..what all electronics will i lose in the car when yanking the ecu car is a 94?
thanks for the help yall
Old Feb 14, 2010 | 02:45 PM
GIZMO's Avatar
The stock fuel pump puts out way to much pressure for a carb. You only need 6-8 psi.
Old Feb 14, 2010 | 03:01 PM
yeah..i know that but a bypass reg will fix that..and then ill run 6psi to the carb..if i cant hook it up to a toggel then ill just tap the tank and run a dead headed system...anyone know if ill run into braking problems with the abs ****..if so looks like im getting a P valve for it.
