lt1 removal questions..
Old Feb 17, 2010 | 07:09 PM
scj's Avatar
scj
Default lt1 removal questions..
'm planning on dropping my motor soon, and I've read all the tutorials I've found, but idk where i can get a cart thing to set the engine on, but I've seen some people drop the engine without the cart thing from the bottom, and they just leave the wheels on the front... is there any tutorial showing how to do this or what? it seems to be a lot easier.
help, thanks.
Old Feb 17, 2010 | 07:15 PM
RamAir95TA's Avatar
You answered your own question.
Old Feb 17, 2010 | 07:22 PM
JB_97ws6TA's Avatar
just leave the wheels on and if you have a strut tower brace it makes it real easy but if not I just had a buddy help stabilize the struts, grab the tailshaft and wheel it around like a wheelbarrow
Old Feb 17, 2010 | 07:28 PM
scj's Avatar
scj
but how do i get the bolts that hold the k member onto the body unbolted with the car on the ground?
Old Feb 17, 2010 | 07:34 PM
RamAir95TA's Avatar
You have to get the car off of the ground.
Old Feb 17, 2010 | 07:41 PM
jaycenk's Avatar
If you have it jacked up by the K member then it wont go anywhere because there are dowls that hold it in place. Just set the stands under the body and lower the K member.
Old Feb 17, 2010 | 07:57 PM
conor.davis's Avatar
Here is one I have looked at before.
http://www.michiganspeed.com/enginepull/index.html
Old Feb 18, 2010 | 12:22 AM
iceman15's Avatar
Not trying to hijack but I will be doing this process next month. What are the 6 cradle bolts they keep referring to?
Old Feb 18, 2010 | 12:25 AM
RamAir95TA's Avatar
There are three on each side under the car that fasten the cradle to the frame rails.
Old Feb 18, 2010 | 12:31 AM
95CamaroLS1's Avatar
Ya its actually pretty easy..
Either get a forklift with a chain, wrap it around the metal brace in front place a pallet underneath the engine with some blocks on the sway bars so when the engine is free it can rest there. Just unbolt and disconnect all the wiring and its on the floor. With me and my dad we disconnected everything in like 2hrs, and dropped it in another 1hr or so.
Oh be careful to not yank the chain to much when lifting the car, cause it will bend the brace. I have see it on other camaros so i was careful.
Old Feb 18, 2010 | 01:27 PM
adamc's Avatar
Default harbor freight
check harborfreight.com and get a movers dolly delivered for about 30 bucks. you can use the movers dolly to get the engine out from under the ride.
Old Feb 18, 2010 | 07:46 PM
scj's Avatar
scj
okay okay, which front brake lines do i disconnect, and where? my car is stock with abs...
Old Feb 18, 2010 | 08:01 PM
RamAir95TA's Avatar
Disconnect the brake lines from the ABS module. Use a GOOD line wrench to avoid stripping the fittings. When pulling the body up, gently move them out of the way.
Old Feb 18, 2010 | 08:11 PM
scj's Avatar
scj
the LF and RF ones labled here?
Old Feb 20, 2010 | 09:03 AM
prostreet67's Avatar
the dolleys from harbor work great used them on two motors last week and were only like 14 bucks. i was worried about doing it at first but after the first one we had the motor out of the donor car in about an hour or so. lot easier then it it looks. just be carefull with the jackstands!
Old Feb 20, 2010 | 11:08 AM
RamAir95TA's Avatar
Just follow the front brake lines to where they join the ABS block. Just takes a bit of looking.
Old Feb 25, 2010 | 07:00 PM
JB_97ws6TA's Avatar
ok I am going to bring this one back...I pulled my motor once before but it was on a lift. This time I am doing it in my garage and someone posted up about the "metal brace" is that the radiator support they are referring to? I would prefer to go off of the frame horns as they did in the write up by michiganspeed but it seems like I have a bundle of wires and some sort of control box on the front passenger side. I was assuming it was for the airbag system but I am not sure. Hopefully someone can clarify or offer another way to pick the damn thing up
