Old May 20, 2016, 10:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
First Mods on stock LT1?
Old Feb 18, 2010 | 10:02 AM
z28muscle51's Avatar
Default First Mods on stock LT1?
Hey guys I'm new on the forum just wanted to get opinions on my car. Ive got a 1995 Z28, T56 tranny, only mod is a K&N intake kit. It's not my daily driver and i'd like to get the car into the 11's maybe 10's, but still be street legal if thats possible. I was wondering what are the first things I should do to my engine to add some horsepower and get setup for future mods. My car does have around 155xxx miles, top end rebuild at 133xxx. Does the bottom end need to be rebuilt before I move forward? Thanks.
Old Feb 18, 2010 | 10:14 AM
97camaross's Avatar
for boltons just leav the bottom end alone for now...You can start with boltons(there is a sticky that fetures all the boltons)LCAs,LCA relocation brackets,PHB,TA,QA1s,and springs...that should get you in the high 12s with a sticky tire...I woould suggest you get a moser 9 inch with 4.11 gears(the stock 10 bolts are really weak).... later on if your planning on running 11s you can go with a stock 355 bottom end rebuild with ARP hardwear, and for the topend go with LE,or AI both are sponsers on here...That would put at 400+whp with a good rear,clutch,sticky tire,and a good driver you will be in the 11s
Old Feb 18, 2010 | 10:15 AM
z_speedfreak's Avatar
lotsa good info in the stickies
https://ls1tech.com/forums/lt1-lt4-m...ewbie-faq.html
Old Feb 18, 2010 | 10:22 AM
pillarpod's Avatar
sticky
Old Feb 18, 2010 | 01:14 PM
slomarao's Avatar
Cai, Exhaust, PCM tune, SFC's.
Old Feb 18, 2010 | 01:21 PM
the_merv's Avatar
Veteran: Air Force
How much you want to spend?
Old Feb 18, 2010 | 01:22 PM
lttransam's Avatar
yup, you want to make the car breath the best you can first.. so then your not choking the motor if you add more power,
Old Feb 18, 2010 | 01:30 PM
MasterTomos's Avatar
Cai, header back exhaust with long tubes and a cutout, subframe connectors, gears, tune, 1.6 Roller rockers will get you into the low 13/high 12 range for starters.
Old Feb 18, 2010 | 01:53 PM
jarretthise's Avatar
i would biuld a good suspension foundation first!
Old Feb 18, 2010 | 02:34 PM
I8ASaleen's Avatar
Money? It will take lots of money to get into the 11's. I would say 5k if you aren't using nitrous. This will include the top-end work and porting, bolt-on's, tires, and most of the suspension.
Old Feb 18, 2010 | 02:39 PM
marc97taws6's Avatar
At 155k on the bottom end, I would personally rebuild the bottom end with quality stuff. $1600-$1900 forged rotating assembly + small other things + machine work.. Then top end work. Issue is you will likely need a new rear once you start getting that fast. 10 bolts are really a hit and miss on powerful t56 cars... mostly a miss.. lol
Old Feb 18, 2010 | 02:50 PM
he said the bottom end was rebuilt at 155k..
like i said build a good suspension foundation first-roughly 1500ish.. sfc, lcas, stb, springs and shocks, then you can get into more suspension after this base suspension build is complete
then for drivetrain- alum ds, clutch, flywheel roughly 1000
motor- cam, pp heads to match cam specs, pp intake, 58 mm tb, 42 lb injectors, egr block offs, i presonally would run a nice balancer, ud pulleys, headers, exhaust.. 2500-3000
then blow your bottom end apart and build a strong *** bottom end.. 355. 383, 388.. make sure you forge next time around though and have it balanced- pricing depends
Old Feb 18, 2010 | 03:03 PM
pyro719's Avatar
Sell it and get an LS1 car or swap in an LQ9
Old Feb 18, 2010 | 03:13 PM
Well how much would it be to bore it .30 over and get bigger injectors and all the stuff that would go with it? Thats stroking it to a 383 right?
Old Feb 18, 2010 | 03:22 PM
djjab57's Avatar
I had my block Boiled, Bored, Honed and Line honed, crank turned and balanced, rotating Assembly balanced for less than $800
Old Feb 18, 2010 | 03:23 PM
no bore & stroke are 2 dif things, .30 over bore = 355. how much it would cost depends on 1) cast or forged 2)new or used 3) machining cost
Old Feb 18, 2010 | 03:34 PM
RamAir95TA's Avatar
A 383 is a rebuilt motor with a new crank (stock is 3.48", a 383 uses a 3.75" stroke) and the cylinders bored .030" over.
Power is made in the valvetrain and cylinder heads, not the overall displacement of the motor.
Old Feb 18, 2010 | 10:45 PM
muddyjimmy's Avatar
Start with all the bolt-on's, trans/rear end, and suspension mods. Start saving some cash for a built long block with a good top end. Spray the snot out of the old motor until it lets go. Replace with built engine. That's my plan at least.
Old Feb 19, 2010 | 01:06 AM
gregrob's Avatar
Nitriss
Old Feb 19, 2010 | 01:16 AM
oboro's Avatar
Redo the hole intake Throttle body,MAF get an intake and an intake manafold try to get 85mm for everything. then re do the whole exhaust from headders with bigest heders you can get and the rest of the exaust got with 3.5" tubing or 4" whatever then get it tuned with a much bigger cam. you will somke alot off ppl.
